Truck won’t start after electric mods completed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Seareef228, Jan 9, 2024.
  1. Jan 9, 2024 at 1:59 PM
    Seareef228
    Seareef228 [OP] Well-Known Member
    Truck will not start...
    I had the driver side kicked panel off. Trying to find a reverse trigger wire. And I was using a teslight to probe around at some of the wires. Nothing major at all, no sparks. Nothing and I went to start the truck and it won't start..
    I've checked every fuse in the eng compartment fuse box and under the dash....HELP PLEASE
    2023trd 4x4 or
    HondaGM likes this.
  2. Jan 9, 2024 at 2:04 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    1. Multimeter the battery, verify that you have a good charge of 12.5 V and that you didn't drain the battery when futzing around.
    2. Did you check fuses visually or did you pull and test them with a multimeter? Blown fuses can sometimes be tricky.
    3. If all else fails, put the kick panel back and have it towed to the dealer.
    TS4x4, shakerhood, Junkhead and 2 others like this.
  3. Jan 9, 2024 at 2:05 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I have to ask the obvious question. Is the battery dead?
    Junkhead, Phlogiston and HondaGM like this.
  4. Jan 9, 2024 at 2:05 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Brand new truck? Get it towed to the dealer. Don't let them blame you for any electrical issues!
    TS4x4 and HondaGM like this.
  5. Jan 9, 2024 at 2:06 PM
    Seareef228
    Battery is fine. This is a brand new truck and I did not drain the battery... I checked every few with a Continuity meter they are all good...not in the mood to tow my new truck...
  6. Jan 9, 2024 at 2:07 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    It cranked till you probed some wires.....?
  7. Jan 9, 2024 at 2:07 PM
    Seareef228
    My problem is they will blame me i've already Put on a germes and other mods ...with a few tap a fuses under the kick panels...
    HondaGM likes this.
  8. Jan 9, 2024 at 2:08 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Your best help will come with a proper thread title. "HELP" is reserved for people in imminent danger/stuck on a trail/lost/etc.
    Maybe something like "Truck won't start/possible short near driver kick panel" or something similar.
    50Buck, Phlogiston, ace_10 and 6 others like this.
  9. Jan 9, 2024 at 2:08 PM
    Seareef228
    Yes it cranked I pulled it out in the driveway this morning now it's stuck
    HondaGM likes this.
  10. Jan 9, 2024 at 2:10 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    When you turn on the switch does the instrument panel light up...does is show what gear its in?
    gilligoon likes this.
  11. Jan 9, 2024 at 2:10 PM
    Off Topic Guy
    When you say won't start, what do you mean exactly? No ACC power, clicking noises, trying to spin over but won't, etc?
    shakerhood, Chew, oconnor and 2 others like this.
  12. Jan 9, 2024 at 2:12 PM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    does it crank or do you get nothing at all?
  13. Jan 9, 2024 at 2:18 PM
    Seareef228
    Hey guys, ok, so when I turn on the key? Everything lights up, there's power to everything. Radio works but it does not start. It does not crack nothing. I put my OBD reader on it and I'm pulling up Apo 452 code.help wtf
    HondaGM likes this.
  14. Jan 9, 2024 at 2:19 PM
    Seareef228
  15. Jan 9, 2024 at 2:19 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    Does it show what gear it is in?...
    MalinoisDad and drizzoh like this.
  16. Jan 9, 2024 at 2:21 PM
    RatFive
    RatFive Member
    The Mountains
    2023 TRD OR DCLB
    If you were doing electrical work and didn’t have the battery disconnected, it’s possible or even likely you blew a fuse somewhere along the way.
    TS4x4, 50Buck, Junkhead and 4 others like this.
  17. Jan 9, 2024 at 2:21 PM
    Off Topic Guy
    Is your gas cap tightened correctly?
  18. Jan 9, 2024 at 2:24 PM
    Seareef228
    Yeah I thought the same thing I just tighten my gas cap it was tight
  19. Jan 9, 2024 at 2:27 PM
    Off Topic Guy
    Here's a wild question; when you added the 'tap-a-fuses', what fuses did you tap into? Start there.
  20. Jan 9, 2024 at 2:33 PM
    Seareef228
    I thought of that also and they all still work
    HondaGM likes this.
