Truck won’t start after electric mods completed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Seareef228, Jan 9, 2024.
  1. Jan 9, 2024 at 2:34 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    See post #15
  2. Jan 9, 2024 at 2:34 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    What do you mean tap a fuse? Vampire taps? This is starting to sound like you broke the evap wire and/or your current draw is jacking up the signal.
    You're going to have to remove those taps and resplice all wires you tapped into.
  3. Jan 9, 2024 at 2:37 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Have you tried disconnecting the battery for 10 min to reset the system u might have triggered a safety mechanism with that code preventing it from starting .
  4. Jan 9, 2024 at 2:38 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I need more pictures to be helpful.
  5. Jan 9, 2024 at 2:39 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Sure those components may still work; doesn't mean its done correctly, or that your truck is happy about it. There's been countless threads with ppl installing raptor lights, or other mods, using add-a-fuse/tap-a-fuse/break-a-fuse/whatever you wanna call them. The truck's ECU doesn't always play well when circuits are overloaded, especially not components that keep the engine running. My advice, undo everything you did, and start over. If that doesn't fix, its a new truck; take it in to the dealer.
  6. Jan 9, 2024 at 2:43 PM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    If it were me:
    1. Get back under the dash + driver's kickplate and undo everything I just did
    2. Electrical tape up any splices if you did anything other than the add a fuse
    3. Check all grounds at the driver's kick plate to ensure nothing is loose / everything is secured to the vehicle chassis
    Keep it simple my dude. Undo what you did then make sure your Taco is getting the signals it needs to start. If there is anyone here with techstream it would be cool to screenshot for duder the ignition circuits and start signals if available.
    I never mess with the vehicle's stock electrical system because of this. My OE tray was fed from the battery through a 100A breaker and had a blue sea mLVD protecting it in case I accidentally left the ditch or bumper lights on. That circuit cuts power if the voltage drops below 12.1 so your start battery has enough juice to crank the taco. Accessories were powered from a Blue Sea Systems accessory fuse panel on the OE tray using negative triggered switched and single pole single throw automotive relays. Never any issues. ECUs are expensive. Check out my build thread linked in sig if you want to see pics of the above.
  7. Jan 9, 2024 at 2:50 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Everything I had tapped in the beginning got moved to an aux tray. I didn’t realize how deep the rabbit hole was.
  8. Jan 9, 2024 at 2:50 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Undo what you did see what happens. It didn't break it's self.
    Junkhead, Phlogiston and Chew like this.
  9. Jan 9, 2024 at 2:51 PM
    Seareef228
    Seareef228 [OP] Well-Known Member
    Ok, guys, here's what I'm gonna do I call the dealer and they said they could see the codes it. Also pulled a p 16 0 4 code which has to do with start ability. I did not splice or cut any factory wires. I only added a few tap times 3. I'm going to undo those fuse taps. Put the original fuses back in. Undo the battery level. Sit for 15 minutes and then try to start it. See what we get fingers crossed.
    mic_sierra likes this.
  10. Jan 9, 2024 at 2:51 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Sorry for your trouble op, but I think you have been given about as much help / advice as you can reasonably get without us being there. I don't blame you for not wanting to have it towed to the dealer as you are correct, they will rightfully blame you for causing this issue. Put it back to stock and go from there.
    shakerhood and Chew like this.
  11. Jan 9, 2024 at 2:52 PM
    Seareef228
    Sorry, bro I keep meaning to answer your question. Yes I see what gears it's in park
    Benny blanco likes this.
  12. Jan 9, 2024 at 2:57 PM
    Buck Henry
    Have you tried starting the truck with the transmission in neutral? Just one more data point to check off.
  13. Jan 9, 2024 at 2:58 PM
    Mr.Gea
    Mr.Gea Well-Known Member
    Gea
    Lancaster, PA
    2020 TRD Sport Cement
    Check your brake light/back up light fuse. If they are blown the truck won't start.
    gilligoon and Junkhead like this.
  14. Jan 9, 2024 at 3:22 PM
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    Tacoma uses a CAN bus protocol I believe, that system doesn't like dirty signals.
  15. Jan 9, 2024 at 3:30 PM
    #35
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    Really?
    I didn't know this wow....
    gilligoon likes this.
  16. Jan 9, 2024 at 3:31 PM
    #36
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    OP, Also, Check ECU-ACC fuse.
    Junkhead likes this.
  17. Jan 9, 2024 at 3:33 PM
    #37
    Seareef228
    So I checked all fuses undid 3 fuse taps and disconnected the battery waited 15 mins still did not start...
    Called the dealer they see my codes and said p1604 poped up...
    I guess it's dealer unless someone has any other ideas ...battery has 12.57 volts
  18. Jan 9, 2024 at 3:36 PM
    #38
    DVR
    DVR Well-Known Member
    SC
    23 TRD Pro
    They should, you F'ed it up
  19. Jan 9, 2024 at 3:37 PM
    #39
    Seareef228
    Thanks for rubbing it in...so nice of you
    ricco333, gilligoon and DVR[QUOTED] like this.
  20. Jan 9, 2024 at 3:38 PM
    #40
    twtaco$
    twtaco$ Well-Known Member
    Check any start fuse. Replace it with a known good fuse. Don't just look at it.
