Truck won’t start, HELP.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fjd24, Jun 12, 2023.
  1. Jun 12, 2023 at 1:45 PM
    Fjd24
    Fjd24 [OP] Member
    2011 TRD
    So I was replacing a a damaged cv boot today and had the front of my 2011 Tacoma jacked up on jackstands. I was working on the right side and had the right tire off the truck. I needed to turn the wheel so I attempted to start the truck. When I turned the key, I got a bunch of flashing lights, but the starter never engaged. Now that the truck is back on the ground, I’m getting similar indications. Any ideas on what the heck I did or how I can fix it? I attempted to jumpstart the truck and no luck. Any help would be greatly appreciated, thanks
  2. Jun 12, 2023 at 1:54 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Could be related or not. Do you have any codes?
  3. Jun 12, 2023 at 1:59 PM
    gunpup
    gunpup Well-Known Member
    Nate
    2015 DCSB Trd OR / 2001 DCSB SR5
    Did the abs sensor wire on that side get stretched and damaged. It runs over the top control arm.
  4. Jun 12, 2023 at 2:01 PM
    Fjd24
    Fjd24 [OP] Member
    2011 TRD
    I need to get a code reader. But could having the truck jacked up and a tire off and trying to start it cause something like that to happen?
  5. Jun 12, 2023 at 2:41 PM
    MR5X5
    MR5X5 Well-Known Member
    That should not have caused a problem. You sure your battery is well charged and well connected?
    Marc70 likes this.
  6. Jun 12, 2023 at 2:50 PM
    Fjd24
    Fjd24 [OP] Member
    2011 TRD
    Will update soon, just had the battery tested and it’s bad. This is a massive coincidence if it’s just a battery since the truck has been cranking up fine.
  7. Jun 12, 2023 at 5:02 PM
    Waasheem
    Waasheem
    2007 xrunner
    Sometimes a battery that tests bad can be brought back. If you don’t have a decent battery charger, you can try jump charging it with another running car. Same as jump starting, just leave it connected for maybe 30 minutes. But if the battery is more than 4 years old, I’d replace it.
    Maybe you had a door open, or music playing to run the battery down? Do the battery terminals look like snowballs?
    michael roberts and RedWings44 like this.
  8. Jun 12, 2023 at 6:14 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Or just a bad starter? ¯\_(ツ)_/¯
  9. Jun 12, 2023 at 9:13 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    That is strange...I can't think of anything that would have caused that from working on a cv axle.
    Any resolution?
  10. Jun 12, 2023 at 9:35 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It depends.
    You can’t test a battery if it isn’t at a full charge.
    You charge it, then test. If it won’t take a charge, you buy a new battery.
    It depends on the tester you (they) used.
    Anyways, it would be a coincidence for sure. Keep us updated.
    Marc70 likes this.
  11. Jun 13, 2023 at 7:12 AM
    Fjd24
    Fjd24 [OP] Member
    2011 TRD
    So just a crazy coincidence but it was a bad battery. Had it tested and it was shot. Cranked right up after new battery. Didn’t mean to waste everyone’s time, still just shocked that it decided to completely die when I tried starting the truck while up on jackstands and the front tire off. Thanks for all the replies guys.
    Jimmyh, Steves104x4, Marc70 and 3 others like this.
  12. Jun 13, 2023 at 8:16 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I deal with it all the time at the shop, the battery has just enough to start the vehicle but leave the key on for a few min checking for codes or diagnosing something and go to start it and "click" :annoyed:
    Most people don't realize their battery is on it's way out until it doesn't start the vehicle.
    I would say about 40% of the vehicles that come in have a weak or bad battery, but it still starts the vehicle (as long as they don't sit with the key on for a few min) so they get by with it.
    Can't wait to how many of these vehicles with the start/stop bs start leaving people stranded when the batteries and starters start dying (already had to rescue a couple), maybe then they will realize how much of a bad idea it is.
    Anyway srry for the rant, glad you got it going and it was minor:thumbsup:
  13. Jun 13, 2023 at 4:56 PM
    Waasheem
    Waasheem
    2007 xrunner
    Usually there’s slow crank before it dies. But occasionally it’s not enough to notice until the new battery is in, then it’ll seem like it cranks fast.
    I had one showing 4v, got it started with my capacitor jump starter but the alternator was straining like crazy. Shut if off, cleaned the snowballs off the terminals, brushed terminals and posts, ended up replacing the battery, it wouldn’t take a charge.
    Dm93 likes this.
