Truck Won’t Start, System Immobilizer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shanek830, Nov 8, 2018.
  1. Nov 8, 2018 at 2:59 PM
    shanek830
    shanek830 [OP] Member
    Shane
    2006 Red Tacoma
    My 2006 Tacoma is having a system immobilizer isssue, and sometimes won’t start. It first happened about a month ago, and I fixed it by unhooking the battery. This same thing happened again today, and I unplugged the battery and it started up again. I’ve tried searching the threads, but haven’t found any answers as to what could be causing it. If anyone has had this issue before and fixed it, I would greatly appreciate any ideas and help before I take it to the dealer. Thanks in advanced.
  2. Nov 8, 2018 at 3:01 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My 08 tundra does that. I find if I leave the key in the ignition overnight it loses communication. I pull the key out and flip it over and it starts right up.
  3. Nov 8, 2018 at 4:59 PM
    Muddinfun
    Muddinfun Well-Known Member
    How have you determined that it's the immobilizer? Does the red light on the dash continue to flash after you insert the key?
  4. Nov 8, 2018 at 5:37 PM
    koditten
    Kirk
    Central Michigan
    The truck cranks and starts momentarily. I can do this multiple times. I pull the key and reinsert it the opposite way and it starts right up and stays running just fine.
    I never remember to look at the imobilizer light to see what it's doing. I'm just happy I'm not a pedestrian.
    Jimmyh likes this.
  5. Nov 18, 2018 at 12:10 PM
    shanek830
    Shane
    2006 Red Tacoma
    the first time it happened, I hooked up my code scanner and that’s the code it threw.
  6. Nov 18, 2018 at 12:13 PM
    shanek830
    Shane
    2006 Red Tacoma
    Mine won’t even start momentarily, it just sits there and cranks. Once I unplug the battery and hook it back up it fired right up
  7. Nov 18, 2018 at 1:04 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Bad chip in the key. Try a different chipped key
  8. Nov 18, 2018 at 1:06 PM
    shanek830
    Shane
    2006 Red Tacoma
    I switched keys after the first time it happened, but it happened again. I’m wondering if it could be the chip reader?
