Truck won't allow me to lock doors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTim85, May 8, 2020.
  1. May 8, 2020 at 10:22 AM
    TacoTim85
    TacoTim85 [OP] Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    My truck is preventing me from locking the doors as if the key is in the ignition (the feature to automatically avoid locking your keys in the vehicle).
    I have a hard key with remote functions (manual trans does not have key fob and push start).
    Here's what happens when you...
    Park.
    Turn the ignition to off.
    Remove the key from the ignition.
    Exit the truck.
    Shut the door.
    Press the lock button on the remote...and nothing happens.
    Press the unlock on the remote... and nothing. (As if the remote batteries are dead. They are not).
    So next I try this...
    Open the door.
    Press the lock button on the door panel...
    The doors lock and immediately unlock themselves. This happens no matter how many times you press the door panel lock button. It will lock all locks and immediately unlock itself.
    Next, I tried using the spare key remote to lock it... nothing. As if the batteries were suddenly dead in it, too. They are not.
    The only way to lock or unlock the truck is by standing outside the driver's door (with it shut) and inserting the key into the door.
    Anyone seen this?
    What's the problem?
    Guessing I'm gonna have to see the dealer.
  2. May 8, 2020 at 10:23 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Is your spare key fob in the vehicle?
    DarkSkyGuy and jerkwithkeyboard like this.
  3. May 8, 2020 at 10:24 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Perhaps there is a bad connection in the ignition/ key hole so the truck thinks the key is still there?
  4. May 8, 2020 at 10:28 AM
    TacoTim85
    There is no key fob, but the spare hard key remote is not in the vehicle. It also does not work if you attempt to remote lock/unlock.
    You would think it would chime or something, but everything else is normal.
  5. May 8, 2020 at 10:44 AM
    JeepinDoug
    JeepinDoug Active Member
    Doug
    2019 TRD Pro Tacoma
    none
    Check some of the obvious first;
    Key fob battery?
    Cycle the key in/out of ign. a few times, maybe a little pen lube.
    Maybe try to cycle the battery, could be a glitch in the ECU.
  6. May 8, 2020 at 10:47 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    This is probably obvious but all doors completely closed and no open door lights on the dash?
  7. May 8, 2020 at 10:54 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Also, pay attention to what the lights in the dash do, or the security light by the AC controls.
  8. May 8, 2020 at 10:56 AM
    Shellshock
    Iowa
    Sounds like the fob battery is dead
  9. May 8, 2020 at 10:57 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think the radio shows some options for door locks too.
  10. May 8, 2020 at 12:07 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    That's true. Could be the fob battery. Leave the key outside, get inside the truck and shut the door, then try to lock it. Should lock, should NOT lock with the door open
    DWD484 likes this.
  11. May 8, 2020 at 12:54 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Gotta ask. Have you done ANYTHING to the truck that you didn't mention??
    G.
  12. May 8, 2020 at 1:15 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Dead battery in key..??
  13. May 8, 2020 at 1:18 PM
    over60
    Muskoka, Ontario
    Try locking the door using door panel then close door... If that works then it's your key not working.
    battery... !!
  14. May 8, 2020 at 2:53 PM
    JeepinDoug
    Doug
    2019 TRD Pro Tacoma
    none
    If it were me and it turns out it's the key fob battery, I would not come back to reply. :rolleyes:
  15. May 8, 2020 at 3:17 PM
    seelyartacus
    seelyartacus Well-Known Member
    San Diego
    '16 TRD Sport 4x4, grey, tech&tow pkg
    FNWheels six shooter matte bronze, Falken WildPeak M/T 295/70/r17, All-Pro Expedition leafs, Fox Factory 2.5 w/ res (front/rear), Icon billet UCA w/ sphericals, custom sliders, 4.56 re-gear, RCI bed rack , Tepui RTT, Prinsu Designs Cabrac, CBI T3 alum front bumper, CBI T3 rear bumper with dual swing away and tire carrier, 20in light bar, Warn VR10s winch, Factor 55 fairlead, flatlink, and hitch recovery point, All-pro alum skid, Rotopax, CMC, Timbren bump stops, rear Rigid Duallys, Rigid Dually ditch lights, ARB awning with LED lights, Currie F9 rear axle housing w/ Strange Engineering 3rd memb and ARB air locker., rear diff beather relocation, ARB compressor under hood, Bussman panel, 3d printed switch panel,OVTune ECU
    Toyota's power door actuators are junk too. but that usually gives 4-6 beeps if that's about to crap out. The part isn't crazy expensive, but not cheap either ($150-250ish) try as a last resort and only if it's not the battery
  16. May 8, 2020 at 3:27 PM
    jmauvais
    NorCal
    ...stuff
    10 posts Doug?
    did that just happen so you created a new account to hide from the dead FOB battery?
    we got you, Doug. Can’t fool us.
  17. May 8, 2020 at 3:44 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    he didn't say BUT it looks like its a 2020... go to the damn dealer....
    Boghog1 and Lt. Dangle like this.
  18. May 8, 2020 at 3:47 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    I had a similar problem last summer in my ‘18 with a 12 volt USB charger that was plugged into the cigarette lighter outlet. Once I unplugged it the problem went away.
  19. May 8, 2020 at 4:24 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I believe if you have a fob in the truck and try to lock it it fires a tornado siren at you. Since your not getting anything, I'd guess it's an issue with the fob.
  20. May 8, 2020 at 7:25 PM
    TacoTim85
    The fob/remote battery is not dead, guys :laugh:.
    I edited the first post to make it more clear what's happening.
    The spare key remote is not in the vehicle.
    Did all of this (minus the pen lube)... even left the battery disconnected 10 mins. No change.
    Yep, first thing I checked while scratching my head.
    Please read original post. Tried it.
    :duh:
    THIS!!! The problem started the same day I plugged in a 12v charger for my handheld radios. That was the first time I'd used this. I unplugged it at some point, and magically the truck is working correctly today. :cookiemonster:
    What kind of weird ass glitch is this? For what it's worth, my Amazon double usb charger that plugs into the 12v outlet does not cause this issue to happen. Thanks for your reply.
