Truck won't come out of 4 lo.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wampas cat, Apr 9, 2022.
  1. Apr 9, 2022 at 7:30 AM
    Wampas cat
    Wampas cat [OP] Member
    Kevin
    2017 Tacoma trd offroad
    My truck is in 4 lo and won't disengage, does anyone have any idea what the problem could be?
  2. Apr 9, 2022 at 7:35 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Shift back to 4 hi and reverse for a little bit then drive slowly forward. Try to keep your wheels straight while you are doing this.
    SR-71A, zoo truck and Mark77 like this.
  3. Apr 9, 2022 at 7:35 AM
    hammerdog
    hammerdog Well-Known Member
    I had same issue one time and this may or may not apply to you. I left my truck parked in freezing temps for about a week and it would not come out of 4 low. I left it running parked in the driveway for about 30 minutes and it got warm enough for the vehicle to go back in 2WD.
    69 Jim likes this.
  4. Apr 9, 2022 at 7:36 AM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I believe is has to be in N to switch in and out of 4lo? You may already know this?
  5. Apr 9, 2022 at 7:36 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    This is possibly due to binding stress…
    If on a grippy surface, under binding stress drive back in the same manner to reverse / alleviate.
    If on low grip surface then just drive for a bit…
    Big tall dave likes this.
  6. Apr 9, 2022 at 7:45 AM
    Wampas cat
    Kevin
    Thanks for all the replies. Nothing seems to help, the 4lo light is blinking, but it is stuck in 4lo. I'm in the mountains in North Georgia and it is cold and snowing, so I'm gonna let it warm up to see if that helps. I gotta drive it back to Alabama tomorrow, can I unplug one or both of the actuators to get it home?
    My4thTacoma likes this.
  7. Apr 9, 2022 at 7:58 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Mine will hang up occasionally. Switching back n forth (with some time inbewteen each shift) usually does the trick for me.
  8. Apr 9, 2022 at 8:02 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Where are you in North Georgia?
  9. Apr 9, 2022 at 8:03 AM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    Maybe driving it a bit in 4 low will also help it to warm up.
  10. Apr 9, 2022 at 8:04 AM
    Wampas cat
    Kevin
    Ellijay.
    My4thTacoma and brandon78lusch like this.
  11. Apr 9, 2022 at 8:10 AM
    Buck Henry
    I live just north of you in Cherry Log. Not sure there is much I can do to help you but I am nearby if you need some tools. Let me know.
    You renting a cabin in Coosawatee?
  12. Apr 9, 2022 at 8:15 AM
    Wampas cat
    Kevin
    Yes, renting a cabin on the mountain between Ellijay and Blue Ridge, thanks for the offer, I have a few tools with me, I'm hoping I can unplug the actuators and drive it home.
  13. Apr 9, 2022 at 8:19 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    I might be mistaken about this but I don’t think unplugging them will disengage the 4 wheel drive. Maybe another member can confirm or debunk this.
    Chew, BigWhiteTRD and Skydvrr like this.
  14. Apr 9, 2022 at 8:22 AM
    Bishop84
    Bishop84 Well-Known Member
    Unplugging wont do anything.
    Keep it unloaded in neutral and keep switching between hi and lo. It may eventually come out.
    SR-71A, Chew, Kev250R and 2 others like this.
  15. Apr 9, 2022 at 8:23 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Select hi range turn the key off then try again. I love my 2011 but the hi/low electronics/operation sucks if I could I would go back to locking hubs and a stick on the floor in a heart beat.
    kairo, tacotoe, 69 Jim and 3 others like this.
  16. Apr 9, 2022 at 8:27 AM
    Buck Henry
    You would not happen to be renting in the Sisson "Cherry Log Mountain" development would you? If so, that is where I am.
  17. Apr 9, 2022 at 8:31 AM
    Wampas cat
    Kevin
    It's either Double Bald mountain or Gobblers Knob, not really sure.
  18. Apr 9, 2022 at 8:42 AM
    My4thTacoma
    My4thTacoma Pain Don't Hurt
    St Petersburg, FL
    2024 TRD Sport 4x4 (Solar Octane)
    beautiful area. I will be in Elijay Memorial Day week. Good luck with your issue.
  19. Apr 9, 2022 at 8:50 AM
    My4thTacoma
    St Petersburg, FL
    By the way, it could be a number of reasons, but I had this happen to me a few times with my Tundra. I had to put the transmission in neutral then push the 2wd button and it would eventually go out of low 4wd. I also remember putting it into 2wd and having to drive like a qtr to half a mile before it would disengage…. Good luck
  20. Apr 9, 2022 at 8:52 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Have you tried driving it forward or backwards and then trying again? Also if you are on a high traction surface, drive it onto a low traction surface and try again.
    Big tall dave and doublethebass like this.
