Truck won't come out of 4 lo.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wampas cat, Apr 9, 2022.
  1. Apr 9, 2022 at 8:54 AM
    overlimit
    overlimit Well-Known Member
    BC C, Eh! N, Eh! D, Eh!
    '21 DCSB TRD OR Premium.
    Are you certain you’re in 4Lo?
    Sometimes when I switch to 4Lo from 4Hi my 4Lo light blinks but it’s still stuck in 4Hi.
    I have to play around with the transmission going between N and D and 4Hi, and 4Lo. Eventually it goes, sometimes with a grind, sometimes with a clunk.
    I also would prefer a manual T-case and locking hubs.
  2. Apr 9, 2022 at 8:56 AM
    Wampas cat
    Wampas cat [OP] Member
    Kevin
    2017 Tacoma trd offroad
    Yes, it's definitely in 4lo.
  3. Apr 9, 2022 at 11:06 AM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    OP
    Flip that bitch in neutral
    Shift to 4HI
    Then shift to 2WD
    It HAS TO BE IN NEUTRAL TO SHIFT OUT OF 4LOW
    If you're having problems, rock it back and forth to get to 4HI and repeat for 2WD
    Lastly, if it's beeping and flashing try turning it off let it sit a few minutes and turn back on rinse and repeat.
    First few times I used 4WD it was being a pain in the ass to get in and out so I worked it and now it goes right in and out locker included.
    Borracho Loco, HV101, 69 Jim and 3 others like this.
  4. Apr 9, 2022 at 2:14 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    If your truck is a manual make sure the clutch pedal is going all the way to the floor. Sometimes a floor mat will cause trouble.
    Big tall dave, 69 Jim, SR-71A and 2 others like this.
  5. Apr 9, 2022 at 2:29 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Did you ever replace your t-case fluid with something other than Toyota LF? I had the same problem as you in the winter after putting 75W90 in the T Case on bad advice. I ran the truck for about 1/2 hour and eventually the exhaust warmed up the T-case and it would shift. Put LF back in there and no more problems.
    Warming up the truck is a good idea.
    RustyGreen likes this.
  6. Apr 9, 2022 at 3:14 PM
    j45p3r
    j45p3r Well-Known Member
    Downeast Maine
    2022 MBM TRD Pro 6MT
    If it’s a manual the clutch has to be all the way down. All. The. Way.
    69 Jim, doublethebass and wilcam47 like this.
  7. Apr 9, 2022 at 3:20 PM
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    Just here to chuckle at "Gobblers Knob."
    :anonymous:
  8. Apr 9, 2022 at 4:04 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    And no joke, Lick Log Mountain is not that far from Gobblers Knob. We are talking north Georgia here.
  9. Apr 9, 2022 at 4:29 PM
    Dauchinouski
    Dauchinouski Well-Known Member
    Bryan
    2017 White Tacome TRD Off Road MT
    Ditch Lights, LED Bumper Bar
    Have you tried checking/changing the fuse?
  10. Apr 9, 2022 at 4:35 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
  11. Apr 9, 2022 at 4:35 PM
    BobbyTacoTRD
    2021 TRD Off Road
    That is amazing. :rofl:
  12. Apr 9, 2022 at 5:14 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes that's pretty much on every thing manual operation. I plow my road all 1/2 mile of it with my truck in low range because I don't need to launch snow 5 feet into the woods and beat the truck up. It is a pain to switch back into high range the only answer I have found is to turn the truck off start all over and try it again. It was so easy with the old truck with the lever on the floor.
  13. Apr 9, 2022 at 6:29 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Can try to diagnose. You got alot of good suggestions already, but if the light is blinking something is probably borked and you are not getting it fixed by driving around, etc.... Disconnecting the actuator electrical connector wont help
    So 2 main options after a visual inspection for obvious faults under the truck.
    Option 1, climb under truck and take the transfer actuator off and manually shift the transfer case into 2hi.
    See this video and do all steps from zero minutes thru 3:54
    https://www.youtube.com/watch?v=GCY2BCdlU4I
    Option 2, apply a couple of volts to pin 1 and 2 on the transfer actuator connector to drive it manually to 2hi. (I dont think I ever recorded which polarity to apply voltage to go to 2hi.)
    See https://www.tacomaworld.com/threads/4wd-actuator-troubleshooting-transfer-case-and-add.578262/
  14. Apr 9, 2022 at 7:17 PM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    LOL....I can see someone doing this for the first time on a muddy cold mountain road in the early morning. Hey...don't loose that plastic gear. Come on Toyota, you should be ashamed.
    Is there an option three....remove that unit, push it into 2WD and leave that unit off?
    incogneato likes this.
  15. Apr 9, 2022 at 9:29 PM
    #35
    saint277
    saint277 Vigilo Confido
    Can't leave the unit off, the shaft is not sealed were it comes through the housing. If you don't want to lose the tcase fluid it needs to go back on.
  16. Apr 10, 2022 at 5:09 AM
    #36
    Spacecoast
    2022 White SR5 2.7L
    Then option four....take it apart....push it into 2WD,and then leave the gear guts out (but put the unit on) until you get home. Or option five...take a stick and hit that transfer unit in the hope that it will function.
    minium likes this.
  17. Apr 10, 2022 at 5:24 AM
    #37
    Mojo Jojo
    Mojo Jojo Well-Known Member
    Mark
    Harpers Ferry, WV
    2020 Pro AG MT, 1997 Land Cruiser
    Tacoma: mid-travel on 33s LC: 3.5” lift on 35s
    If it's a manual transmission, I echo the other posts above. The clutch has to be pressed firmly into the floorboard to get in and out of 4Lo, can't be any gap between the pedal and floorboard.
  18. Apr 10, 2022 at 5:26 AM
    #38
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Pennsylvania is no better with names like Bird in Hand and Intercourse :)
  19. Apr 10, 2022 at 6:17 AM
    #39
    pltommyo
    pltommyo Well-Known Member
    Tom
    2016 Gray Tacoma TRD Offroad
    SSO hybrid bumper, Warn winch, RCI skid trilogy, RRW sliders, everything in the cheap/free mods thread, and of course the frame recall work.
    Michigan ain't so bad .. but in 5 hours you can drive from Paradise to Hell.
  20. Apr 10, 2022 at 11:17 AM
    #40
    Fredk
    Fredk Well-Known Member
    Fred
    Dark grey 2020
    I thought is was knob gobbler.
    doublethebass likes this.
