Truck won't come out of 4 lo.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wampas cat, Apr 9, 2022.
  1. Apr 12, 2022 at 5:25 PM
    #81
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Yeah and ok when dry too if you’re on the highway for 10mi. It’s the right turns that’ll bind the drivetrain
  2. Apr 12, 2022 at 6:01 PM
    #82
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Out of curiosity, what is the purpose of the hose that connects to the actuator?
  3. Apr 12, 2022 at 6:20 PM
    #83
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Breather line.
  4. Apr 12, 2022 at 6:48 PM
    #84
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The syncro is designed to hold in the cog in place. It should not pop out unless it is worn out. Also, those plastic gears are not designed for the constant load of holding the cog in place, they would shear.
  5. Apr 12, 2022 at 6:57 PM
    #85
    saint277
    saint277 Vigilo Confido
  6. Apr 12, 2022 at 7:04 PM
    #86
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    It is still plastic and the rod is steel... eventually something will win.. the syncro is a triple syncro, just like what is found in a manual transmission. Try to pop one of those out of gear under load... that is gonna be tough and violent when it does pop out.. that is why it has to be unloaded to shift. The directions for the transfer case shift on the fly are no different. You need to release the accelerator to get it to shift easier.
  7. Apr 12, 2022 at 7:05 PM
    #87
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    4H going straight on wet pavement should be fine.... better to do it on dirt/snow though. There's no reason to ever get into 4L on pavement... only for offroad use!
  8. Apr 12, 2022 at 7:07 PM
    #88
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I exercise the 4lo shift by using the 2lo mod. I do it at least once a month. In a parking lot.
    At Walmart :anonymous:
    doublethebass and Junkhead like this.
  9. Apr 12, 2022 at 7:12 PM
    #89
    saint277
    I don't know, the plastic gear seems to win every time I shift to and from 4x4.
  10. Apr 13, 2022 at 9:22 PM
    #90
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    Exactly why I try to come back and provide updates to questions when I ask them….. including my own ‘4wd light blinking’ thread that didn’t get much traction, except for from you. Thanks again for always chiming in when we need a nudge in the right direction.
    BigWhiteTRD[QUOTED] and bush rat like this.
  11. Apr 15, 2022 at 12:49 PM
    #91
    Wampas cat
    Wampas cat [OP] Member
    Kevin
    2017 Tacoma trd offroad
    Sorry for bailing out on everyone, I did make it home, I took the actuator off,pushed the shifter rod in 2wd,left the gears out of the actuator, put it back on and drove home.
  12. Apr 15, 2022 at 1:11 PM
    #92
    minium
    Glad you got back.
    You will need this, check the photos. There is a video up somewhere as well, shows the process but not as detailed.
    https://www.tacomaworld.com/threads/4wd-won’t-engage-disengage.696584/
    Good luck.
    RustyGreen and BigWhiteTRD like this.
  13. Apr 15, 2022 at 4:14 PM
    #93
    OnHartung'sRoad
    Damn, and we all hoped it would be a great survival story. o_O
