Truck won't crank after the temp goes up! (HELP!)
Discussion in '1st Gen. Tacomas (1995-2004)' started by TxTacoma95, Oct 18, 2019.
  1. Oct 18, 2019 at 4:41 AM
    TxTacoma95
    TxTacoma95 [OP] New Member
    1995 Toyota Tacoma
    I have a 1995 Toyota Tacoma single cab that has ran great for years. But now when I'm running the A.C and the temperature outside is hot once I turn it off, it won't start until it cools down a bit. I wait 5 to 10 minutes and it cranks up. It's not running hot or anything like that. Has anyone else had an issue like this?
  2. Oct 18, 2019 at 7:06 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Purge selnoid stuck open or not sealing/leaks. Before hot start open gas cap, close it. Floor the go pedal on first crank. Second crank fires right up? = Replace purge selnoid.
  3. Oct 18, 2019 at 7:09 AM
    Truggin
    Truggin What a long, strange trip it's been
    Don
    39.15737720308645, -77.92212986904099
    Black 2016 TRD Sport V6 4x4 Access Cab
    It's a work in progress. See my build thread.
    I had a starter that wouldn't crank when hot. Replaced it and boom.
  4. Oct 18, 2019 at 7:12 AM
    Glamisman
    Glamisman Well-Known Member
    If you mean that the starter doesnt crank the motor then yes... the starter has what is called heat soak. This is usually an indication that there is an issue with the cables that go to the starter, the cable ends at the battery, the starter or the grounding system. A voltage drop test preformed by a good tech can determine if it is one or all of the things I mentioned. Taking it to an auto parts store and having them check the amperage draw via an inductive tool can lead you down the wrong path, they WANT to sell you parts, not necessisarily the parts you need to fix your problem.
  5. Oct 28, 2019 at 3:55 AM
    TxTacoma95
    1995 Toyota Tacoma
    Thanks, everyone for your info. It will turn and turn, just won't crank until it drops a few degrees in temperature. I can let it sit for days/weeks and it will always crank right up. Just when I have the A.C on and it's hot outside the temp gauge doesn't get high or overheat while driving, but it will just shut off and not crank for a while. I'm frustrated with it and want to try to fix it myself before taking it to a shop.
