Truck won't crank this morning!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sxe4533, Sep 10, 2017.
  1. Sep 10, 2017 at 12:45 PM
    sxe4533
    sxe4533 [OP] Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    It sound like my battery already dead! Little to soon i think! No warning or any error codes appears on display! Juat wont start, I measured 12.4votls should I go replace it at AutoZone or wait for dealership to open tomorrow?
  2. Sep 10, 2017 at 1:05 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you have a jump starter pack you can see if that will help start it, otherwise you might as well wait till you can get it to the dealer.
  3. Sep 10, 2017 at 1:06 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Check your water levels. Charge it if you have a charger. 12.4 volts when it i sitting there doesn't matter. The voltage will drop when you turn over the starter. You are probably dropping to about 7-8 volts when are cranking the engine over. Which isn't enough to start it.
    use distilled water if the water levels are low.
    shakerhood likes this.
  4. Sep 10, 2017 at 1:44 PM
    Tacuache345
    Tacuache345 Well-Known Member
    Mario
    Los Angeles, CA.
    2016 DCSBOR/BBP
    None
    Mine was replaced,with only 10k miles due to battery leaking fluids.
    Joe23 and shakerhood like this.
  5. Sep 10, 2017 at 2:04 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    I did put a jump starter on it and it cracked right up! So definetly battery! The question is with all the tech future I was thinking there should be a maintenance light with check battery or sonething!!right? The other thing is should I cough up 150$ at AutoZone or stay home today since all dealer close on Sunday and try to go make them replace it under warranty tomorrow!? I'm a month shy from2 years and 43k miles so far!
  6. Sep 10, 2017 at 2:16 PM
    shakerhood
    Southern Ohio
    If you have 43k I think you are out of warranty unless you bought something extended.
  7. Sep 10, 2017 at 2:19 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    I have the platinum 100k miles warranty! Wasn't sure if that cover the battery!
  8. Sep 10, 2017 at 2:20 PM
    shakerhood
    Southern Ohio
    That should be covered from what I can remember
    sxe4533[QUOTED][OP] likes this.
  9. Sep 10, 2017 at 2:20 PM
    FHC
    FHC Well-Known Member
    My 2004 Tundra's battery lasted 10 years and still worked when I replaced it and I live in a cold climate!
    Hobbs and shakerhood like this.
  10. Sep 10, 2017 at 2:26 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    Yeih by Benz side at 7 years! That's why I was pretty surprised when my truck had a little hick up starting yesterday thought maybe I got dirty gas somewhere then this morning the igniter tried few times before it cranked so drove to the gas station and filled up after that it didn't crank at all tried a couple of times before I put the jump starter on it!
  11. Sep 10, 2017 at 2:31 PM
    ICU1
    ICU1 Well-Known Member
    Toyota. "It's normal"
  12. Sep 10, 2017 at 2:35 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    So if dealership complained about replacing it what battery u all recommend?
  13. Sep 10, 2017 at 2:37 PM
    shakerhood
    Southern Ohio
    I always get nervous talking about batteries cause I'm afraid I am going to jinx myself. I think in all the vehicles I've owned I only had 1 battery crap out early. I've had 13, 11, and 9 year old batteries still function fine, now that I said that I will probably have a dead battery...
    FHC[QUOTED] and tcjacado like this.
  14. Sep 10, 2017 at 2:38 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I like Interstate.
    I'd avoid Optima, they're shit.
    Hobbs, koditten, 69others and 5 others like this.
  15. Sep 10, 2017 at 2:46 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    Yeih I didn't want to throw 250 on a optima!
  16. Sep 10, 2017 at 2:50 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I just keep going back to Costco batteries. Price is right, return policy is great and they've outlasted their service life in almost any occasion I can think of...
    Most batteries are made by one or two manufacturers despite the label. Believe The Costco and walmart batteries are all made by Johnson controls???
  17. Sep 10, 2017 at 2:54 PM
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    Don't have Costco membership but sam' s should be quite similar
    smitty99[QUOTED] likes this.
  18. Sep 10, 2017 at 2:59 PM
    shakerhood
    Southern Ohio
    I think Johnson Controls makes the majority of batteries sold under tons of different brands, I would try to find 1 with the best warranty if Toyota does not give you a new one.
    smitty99 likes this.
  19. Sep 10, 2017 at 3:05 PM
    smitty99
    Scottsdale
    Yep
  20. Sep 10, 2017 at 5:00 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    What is the alternator putting out? It could be a bad regulator and its frying the battery- I'd take it to the dealer if it's still under warranty. Have your battery dealer who ever you go to check it, but if you have a warranty use it.
