Truck won't crank this morning!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sxe4533, Sep 10, 2017.
  1. Sep 10, 2017 at 7:23 PM
    #41
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Adding distilled water is a common maintenance for automotive batteries. Your dealer will do it also. You should also use a hydrometer to test the specific gravity of all of the cells. Make sure your terminals are cleaned. Checking and adding water isn't tampering with the battery. Thats like saying adding checking and adding oil will void your warranty.
    shakerhood likes this.
  2. Sep 10, 2017 at 7:29 PM
    #42
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    The Costco batteries are the same everywhere. They say interstate but are made by Johnson Controls.
  3. Sep 10, 2017 at 7:33 PM
    #43
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Not necessarily. And technically they can void your warranty if you add oil. If it's proven too much or little was added, sure they can. There is a stipulation for everything. My buddy was a diesel tech at out dodge store. His crankshaft snapped on his dart. Still in powertrain. He did his own oil changes being a tech. Fiat wanted his oil receipts which he didn't have. The service manager had to pull some strings and pull some receipts out of his ass for him to get the motor covered.
    I'm sure Toyota has no guidelines for any battery maintance. When you put the electronic tester on it and the battery fails it's a simple replace. Ford, Honda, Chevy I can all tell you operate this way. We don't go into the parts department and grab a 20oz bottle of distilled water, add and retest. I do remember the old Toyota Panasonic batteries having the eye for telling you to add water.
  4. Sep 10, 2017 at 7:50 PM
    #44
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Tacoma Batteries used to have that little glass window and it changed colors, still simple enough to pop the caps off the current battery to check the level though.
  5. Sep 10, 2017 at 7:51 PM
    #45
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Yep, the old Panasonic batteries. They had the eye on top
  6. Sep 10, 2017 at 10:46 PM
    #46
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    If the alternator works, that's good but a bad regulator will make the alternator overcharge and eventually kill the battery. Should get that checked before putting in a new battery- most service people will do that if you have them install a new battery with a warranty.
    Herniator likes this.
  7. Sep 11, 2017 at 8:59 AM
    #47
    sxe4533
    sxe4533 [OP] Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    well there was caps on the battery that i was able to pop off! visually it looks like they got water in them ! i think ima do Costco 82$ +60 membership still better then most i just dont like Walmart touching my vehicle and Sam's club dude sounded like an idiot on the phone!
  8. Sep 11, 2017 at 9:04 AM
    #48
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    crazy thing is that the battery thats in my truck now is only 582 amps isn't that little low!
  9. Sep 11, 2017 at 9:07 AM
    #49
    shakerhood
    Southern Ohio
    Did the Dealer not cover the old battery? Be careful swapping the battery as the Oil Filler Tube is only glued on and if you bump it with the battery it will probably come off.
  10. Sep 11, 2017 at 10:30 AM
    #50
    Jaybez
    Jaybez Well-Known Member
    Fort Mill, SC
    2016 Tacoma TRD Sport 4X4
    Definitely not too soon. I had to replace the battery in my 16' last month. It had a bad cell. Dealer covered the replacement though.
  11. Sep 11, 2017 at 11:16 AM
    #51
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Doesn't Interstate make Optima?
  12. Sep 11, 2017 at 11:22 AM
    #52
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Don't know, but there is a world of difference between the two in durability and reliability.
    I've never had an Optima last more than 18 months. Every Interstate has lasted well over 5 years. My last replacement was 7 or 8 years old.
    Red tops, yellow tops.. all have been shit.
    smitty99 and shakerhood like this.
  13. Sep 11, 2017 at 11:28 AM
    #53
    sxe4533
    Edmond, OK
    2016 TRDORDCSBAT
    so i asked my co-worker to give me a jump start with his little corolla and his had a 380 amp battery wasn't enough juice to start my truck had to get a real car to do so! whats up with Toyota are they that cheap to put in an adequate size batteries in those vehicles!!!!
  14. Sep 11, 2017 at 12:10 PM
    #54
    nDub
    Lead Free Gasoline
    Bummer. I have a red top in my '85 that is about 13 y/o. Maybe quality has gone down since then.
    I agree though that generally Interstate makes the best battery.
  15. Sep 11, 2017 at 12:11 PM
    #55
    shakerhood
    Southern Ohio
    They downsized from a 27F to a 24F from 2nd to 3rd Gen but i think you can use a battery tray from a 2nd Gen if you want a bigger battery.
    nDub likes this.
  16. Sep 11, 2017 at 12:14 PM
    #56
    shakerhood
    Southern Ohio
    IIRC Johnson Controls makes both Interstate and Optima, think they bought Optima a few years back and lowered the quality.
    nDub[QUOTED] likes this.
