Truck Wont Move in 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GTVAPSAMTIK, Oct 2, 2009.
  1. Oct 2, 2009 at 2:28 PM
    GTVAPSAMTIK
    GTVAPSAMTIK [OP] Well-Known Member
    SOHAIL
    Fort Carson, CO
    2010 TRD OFF-ROAD 4X4 Automatic
    EXTANG Tuff WeatherTech Liners Toyota Bed Mat Coverkind Seat Covers
    Hi All Ive had my 2010 Tacoma TRD OFFRoad for 3 days now, I am still kind confused with all these new buttons like LSD/RearLockDiff. Yesterday when I was testing it around, I put the truck in H4x4 for the first time and drove around the block. When I was about to park the truck and turned the steering all the way to Left or Right, The truck stoppped moving (like it had parking break on). I had to hold down the accelerator a little to make it move (automatic transmission). And every time I let go of accelerator it would just stop moving like brakes are pressed or something.
    Now is this normal for these trucks not to move in 4x4 while turning hard ? Am I doing something wrong here ? ALso this is my first Truck.
  2. Oct 2, 2009 at 2:29 PM
    jmasterj
    jmasterj Samsonite...I was way off!
    07 TRD Off Road
    Do not turn your truck on dry pavement in 4x4.
  3. Oct 2, 2009 at 2:36 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    what he said.
  4. Oct 2, 2009 at 2:39 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Why?
  5. Oct 2, 2009 at 2:40 PM
    jmasterj
    07 TRD Off Road
    The owners manual I think states to use your truck in 4x4 each month for 10 miles, (I don't remember exactly), but you should do it in a straight line, etc. Turning on dry pavement is putting a tremedous amount of stress on your drivetrain. I'm sure Chris4x4 will be around to explain exactly why.
  6. Oct 2, 2009 at 2:41 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    It binds the drivetrain...
  7. Oct 2, 2009 at 2:43 PM
    Masada
    Taylor
    Laveen, AZ
    Could you explain a little more? I'm no mechanic and my understanding of 4x4 workings is limited.
  8. Oct 2, 2009 at 2:45 PM
    jmasterj
    07 TRD Off Road
  9. Oct 2, 2009 at 2:47 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Part time 4x4 systems are designed for off road use or low traction situations like snow. There are systems (usually called all wheel drive) like Subaru and Audi quattro that can be used on dry pavement.
  10. Oct 2, 2009 at 2:48 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  11. Oct 2, 2009 at 2:57 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Read the links that were provided....they'll help a lot.
    Anytime you're in 4WD and the truck doesn't want to move - DON'T FORCE IT.
    That's a sign that the driveline is binding. If you force it to move, you could break something. The CV axles on the front axle shafts can pop out if you're running in 4WD and making tight turns.
    If the truck doesn't want to move - straighten the steering wheel, take it out of 4WD, then try to move it forward or backward slightly until it comes out of 4WD. Don't be surprised if after you've taken it out of 4WD (button or lever) - the truck stays in 4WD (light on the dash) for a bit afterwards. The truck won't disengage until all the torque-load is released from the driveline.
  12. Oct 2, 2009 at 3:10 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Never use your 4x4 on the concrete in turns, it will chop up your tires. learn about your stuff before you use it btw you don't want to break anything.
  13. Oct 2, 2009 at 3:10 PM
    SubZombie
    SubZombie Well-Known Member
    South East
    2019 Voodoo TRD Pro
    I can't believe some people still don't know not to drive around on pavement with 4wd engaged. In a straight line down the highway to lube the system up is OK, but turning on pavement can break something in no time.
  14. Oct 2, 2009 at 3:16 PM
    GTVAPSAMTIK
    SOHAIL
    Fort Carson, CO
    Thats exactly what happened, when I took switch frmo 4x4 to H2 the 4x4 light was blinking and I wasnt sure what to do to stop it.
    As manual say so, thats the only reason I was using 4x4 for first time. I never go OFF ROAD , not sure why I purchased Off road instead of SPORTS. BTW this is my first truck.
  15. Oct 2, 2009 at 3:23 PM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    I would jack up the whole truck to get rid of that driveline bind. Stomping the gas in 4 wheel in the driveway isnt recommended. Im sure that rear locker if it is on isnt helping either.
  16. Oct 2, 2009 at 3:23 PM
    krimson
    krimson Nothin
    TRD Off Road
    X2
  17. Oct 2, 2009 at 3:27 PM
    GTVAPSAMTIK
    SOHAIL
    Fort Carson, CO
    Guess I was abusing this new truck. Is there not to do list for NEWB truck owners ? BTW Thank you all for your input I am glad to be a part of these fourms. That stopped me from ruining my new truck, I have 79 Miles on it so far.
  18. Oct 2, 2009 at 3:27 PM
    Masada
    Taylor
    Laveen, AZ
    Gee isn't it great then to have a sight like this where people can ask these questions?
  19. Oct 2, 2009 at 3:28 PM
    TacoMOnster07
    TacoMOnster07 Well-Known Member
    Pennsylvania
    07 DC 6speed 4x4 BSP Sr5
    BHLM, Grillcraft, Urd SS, Urd TCAI, Urd MAF Calibrator, AeroTurbine Exhaust, TacoTune Single Din, Two 8" Infinity Subs, 12-13000 HID's, Xtreme Bedrack light bar with two KC 4 by 6 lights.
    I'm sure we all didn't read the manual before we drove our Tacomas and pushed every button while at it. Give him a break he asked us a question about his truck because obviously he's interested in learning and having fun with his truck. I never binded bad until trying to back up in 4x4 while turning sharply. What happens is your front transfer case is rotating both front wheels at the same speed. This is bad when your turning sharply because it doesn't allow the outer wheel to spin faster to cover more distance.
  20. Oct 2, 2009 at 3:30 PM
    ST088
    ST088 Active Member
    Louisiana
    09 Double Cab 4x4 TRD offroad
    Damn!!
