Truck Won't Move
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buster888, Oct 12, 2020.
  1. Oct 12, 2020 at 3:49 PM
    Buster888
    Buster888 [OP] Well-Known Member
    Nova Scotia
    Tacoma TRD Trail Teams Sport
    Bed mat, Extang Cover, Shorty antenna, Pop'n Lock, Interior and Plate LEDs.
    So this morning I jump in my 2014 Tacoma and no reverse no forward in any gear. E-Brake is snapped back in place as usual. Tried the E-Break forward and back several times. No luck. Anyone ever had this problem? Had new tires put on last week. (KO2s) Any ideas folks?
  2. Oct 12, 2020 at 3:51 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does the engine rev up?
    Or does if feel like the brakes are holding it in place?
  3. Oct 12, 2020 at 4:32 PM
    Buster888
    Nova Scotia
    Revs right up. Feels like the passenger front tire is locked. It seems to dip when I try forward and reverse. (manual transmission)
  4. Oct 12, 2020 at 4:39 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    If you have a Jack try getting the truck off the ground and see if each tire will spin by hand.
    Clearwater Bill and TnShooter like this.
  5. Oct 13, 2020 at 5:32 AM
    Buster888
    Nova Scotia
    Okay, I'll give that a try. Thank you.
  6. Oct 13, 2020 at 5:36 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Sounds like a seized caliper. You could try tapping it with a hammer to see if the piston retracts but might be time for front brakes including new calipers or at least rebuilding them.
    dangeroso and Wattapunk like this.
  7. Oct 13, 2020 at 5:55 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Given your location, I would say seized brake calipers due to rust would be high on my list of causes.
  8. Oct 13, 2020 at 6:15 AM
    Greenedmc
    Daniel
    Elizabethton TN
    If it does end up being a seized caliper I’d probably go ahead and replace the rubber brake hose too as a preventative measure since you’ll already have one end of it off and have to bleed the braking system
  9. Oct 13, 2020 at 7:53 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    10 bucks says stuck rear brake drums. pretty common in the wet n cold climates.
  10. Oct 13, 2020 at 8:40 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    This. I also had to stop using my parking brake because the bell cranks wouldn't return. Took a tap with something to get them in the released position.
  11. Oct 13, 2020 at 8:44 AM
    nd4spdbh
    SoCal
    I have only ever had it happen to me once. Backed the truck into the water to launch some stand ups out of the bed of the truck, truck was DEEP, water just touching the bottom of the frame rails under the doors, needless to say the drums were DUNKED.
    I parked the truck to go on a 3 day houseboat trip n went, hmm do i set my parking brake the drums are def wet eh yaaaaaa ill be fine. Sure nuf got back a few days later and couldnt move as the shoes had frozen to the drums. Needed 4low and some rocking back n forth for it to pop!
    Never had an issue in the snow and rain in the mtns tho.
  12. Oct 13, 2020 at 9:45 AM
    CroResident
    CroResident Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    As crazy as this sounds, my 2015 DCSB 4x4 did the SAME thing. I ended up removing the passenger rear brake drum, freed up the brake shoes with a hammer, and drove it home. Before i got it home, my brake pedal was going to the floor and barely slowing down the truck (later i found out that this was due to the brake fluid getting extremely hot after driving with the drum brake stuck all the way home). when i got home, i discovered that the only way to free up that passenger side rear brake drum, was to disconnect the parking brake cable from the passenger rear brake assembly. Come to find out, the parking brake cable was pinched. I have no idea how that happened. I confirmed that it was pinched by trying to move the cable in and out of the "cable sleeve thing" once i completely removed it from the truck. I went to the dealer and ordered a new parking brake cable and installed the new on on my truck. Problem solved. I still have the seized cable to show people. Still have no clue how that happened.
    BassAckwards likes this.
  13. Oct 13, 2020 at 3:58 PM
    Buster888
    Nova Scotia
    It's still fairly warm here so it's not from cold weather. Jacked up the truck today and all wheels are stuck to the point of about 1/4 turn. Thinking the e-brake is stuck somehow. Works inside ok but that doesn't free up the wheels. Your thoughts?
  14. Oct 13, 2020 at 3:59 PM
    Buster888
    Nova Scotia
  15. Oct 13, 2020 at 3:59 PM
    TnShooter
    Deogee
    STOCK
    If all the wheels are stuck including the front, I don’t see how it could be the E-brake.
    It only operates off the rear wheels.
  16. Oct 13, 2020 at 4:00 PM
    Buster888
    Nova Scotia
  17. Oct 13, 2020 at 4:01 PM
    Buster888
    Nova Scotia
  18. Oct 13, 2020 at 4:02 PM
    Buster888
    Nova Scotia
  19. Oct 13, 2020 at 4:02 PM
    TnShooter
    Deogee
    STOCK
    If both Rear and Front wheels are “stuck”, I am going to say it’s probably NOT the E-brake.
  20. Oct 13, 2020 at 4:07 PM
    ShimStack
    Ben
    NC
    *ALL* the wheels?????
    Greenedmc and TnShooter like this.
