Truck wont REV
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jafo2014, Mar 21, 2025.
  1. Mar 21, 2025 at 11:57 AM
    jafo2014
    jafo2014 [OP] New Member
    2014 Super White Tacoma Access Cab
    2014 Tacoma Access Cab. So I needed a new battery. Installed the new battery and now my truck will not Rev pedal to the floor just idles at 1000. Lights on the cluster are (check Engine, and TRAC off). Disconnected battery let capacitors deplete checked fuses. AT A LOSS. Am I missing something?
    Yes, I did install the battery correctly.
    Any Advice greatly appreciated
  2. Mar 21, 2025 at 1:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check the ECTS fuse in the underhood fuse box, not uncommon for it to blow with a weak battery and/or jump start.
    If that's good you will need to see what code(s) you have.
    Jimmyh likes this.
