Truck won't roll freely in neutral
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ironworker84, Oct 9, 2020.
  1. Oct 11, 2020 at 12:38 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you have a very poor sense of smell or bad head cold you might not be able to smell a hot brake or brakes !
    It is possible to have a failing wheel bearing not making noise but most times something is going to be leaking .
  2. Oct 23, 2020 at 12:30 PM
    Ironworker84
    Ironworker84 [OP] Well-Known Member
    Eric
    2001 White Tacoma 4X4
    So i jacked up one tire at a time. The fronts roll freeley. New brake pads, bled the brake fluid. Now when the truck has been sitting for a while. And i go to accelerate the truck absolutely wont budge. Then out of no where BANG and it will move. Or i will barely touch the brakes and its like im slamming them on. WTF IS HAPPENING?
  3. Oct 23, 2020 at 12:31 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Did the rears roll freely when you jacked them up???
  4. Oct 23, 2020 at 12:34 PM
    81shark
    81shark Well-Known Member
    do you park with the parking brake on?
  5. Oct 23, 2020 at 12:36 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    It goes Bang?? Or that was just a expression ??
    Auto Transmission ??? Might not be a brake issue
    wilcam47 likes this.
  6. Oct 23, 2020 at 12:59 PM
    Ironworker84
    Eric
    Nope. I was under the assumption they should not roll freely unless the transfer case is in neutral.
  7. Oct 23, 2020 at 1:00 PM
    Ironworker84
    Eric
    Yes and i put it in gear
  8. Oct 23, 2020 at 1:00 PM
    Ironworker84
    Eric
    No thats the actual sound i hear. And its a 5 speed manual
  9. Oct 23, 2020 at 1:00 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    No. Put transfer case in 2hi / 2 low and trans in neutral and jack both rear wheels off the ground. The rear wheels will spin at the same time, but they'll spin freely if the rear brakes are properly set up. Is your transfer case or transmission not going into neutral for some reason?
  10. Oct 23, 2020 at 2:17 PM
    Ironworker84
    Eric
    Transmission and transfer do go into neutral but the wheels do not spin freely
  11. Oct 23, 2020 at 2:21 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Even when both rear wheels are off the ground at the same time?
  12. Oct 23, 2020 at 2:21 PM
    Ironworker84
    Eric
    Correct
  13. Oct 23, 2020 at 2:24 PM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    If both rear wheels are off the ground with the parking brake off it shouldn't matter if the transmission or transfer case work or not.
    Spin one wheel and the other will spin the opposite way. It won't matter if the driveshaft can turn or not.
    If you hold one wheel fixed and spin the opposite then the driveshaft will have to be able to spin. If you're in gear or the drivetrain has a problem then nothing will spin.
    If you have both wheels off the ground and the parking brake is supposed to be off but is hanging up then nothing will spin or it might be very difficult. That's the brake hanging up.
    Dalandser likes this.
  14. Oct 23, 2020 at 2:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    To be clear.
    The transmission WAS in Neutral when checking the wheels for rotation?
    And neither wheel will spin?
    DaveInDenver and Dalandser like this.
  15. Oct 23, 2020 at 2:39 PM
    #35
    Ironworker84
    Eric
    Yes correct. They do not spin freeley. And it just occured ro me as well that ive never changed out the manual transmission fluid. Son of a bitch
  16. Oct 23, 2020 at 2:42 PM
    #36
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Is that with the engine off?
  17. Oct 23, 2020 at 2:54 PM
    #37
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    lol
  18. Oct 23, 2020 at 3:03 PM
    #38
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    throwout bearing if a manual?:notsure: Probably Not!
  19. Oct 23, 2020 at 3:14 PM
    #39
    81shark
    Seems like the parking brake is hanging up. I'd defiantly check the cables and brake hardware.
  20. Oct 23, 2020 at 3:16 PM
    #40
    Ironworker84
    Eric
    Yes with the engine off
