truck wont shift to reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by untuckedtaco, Dec 3, 2013.
  1. Dec 3, 2013 at 2:35 PM
    untuckedtaco
    untuckedtaco [OP] Well-Known Member
    Kyle
    Chesapeake 23323
    DCSB 08 SAS'ed/REBUILDING
    Surprises
    Change my reverse bulbs, one blew immediately and then the other went out. cant find a blown fuse, its almost as if the shifter doesnt know that the brake pedal has been depressed. is there a simple solution?
    4.0L Auto
  2. Dec 3, 2013 at 2:52 PM
    untuckedtaco
    Kyle
    Chesapeake 23323
    Surprises
    zero fuse blown, brake lights are functioning perfectly. Where is the shift lock override at?
    PS Thank you
  3. Dec 3, 2013 at 4:56 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Check the IG1 and IG1 no.2 fuses - you know about the fuses behind the dash fues panel, no?
  4. Dec 3, 2013 at 8:16 PM
    untuckedtaco
    Kyle
    Chesapeake 23323
    Surprises
    Also my blinkers don't work but hazards do
  5. Dec 3, 2013 at 8:22 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Brake light fuse located in interior fuse panel, behind change tray to left of steering wheel. If you blew a fuse, as always, it's probably the last thing you did. I have never burned out a reverse light bulb.....perhaps you put some sort of "high output", fancy bulb in there? Change the appropriate fuse, go back to stock bulbs, see if problem goes away.
    Been discussed before: http://www.tacomaworld.com/forum/2n...n-signals-wont-shift-out-park-more-fixed.html
  6. Dec 3, 2013 at 9:16 PM
    untuckedtaco
    Kyle
    Chesapeake 23323
    Surprises
    ok, located the fuse at fault, couldnt see it visually, actually had to break out a voltmeter to find it, replaced it, everything functions but i still have a P0705 code and my check engine light is still on. do you think a simply removing th ground for a few minutes might clear the code?
  7. Dec 3, 2013 at 10:03 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yeah, pulling the negative cable should clear the code.
  8. Jan 18, 2015 at 5:00 PM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    Going with a thread revival here.... Do you recal what fuse it was???
  9. Jan 18, 2015 at 5:15 PM
    IowaToyotas
    IowaToyotas Well-Known Member
    Matthew
    San Diego
    13 TRD Super Charged
    Super Charger, 2 In lift, TRD pro 17in Rims, 285 Toyo all country tires
    Its the fuse for the shifting solenoid can't remember which is was.
