Truck Wont Start after fueling
Discussion in 'Technical Chat' started by mactruckx2, Sep 16, 2012.
  1. Sep 16, 2012 at 9:07 AM
    mactruckx2
    mactruckx2 [OP] Member
    Mac
    San Diego
    02 Tacomma
    Sound System
    Strange problem...after fueling the truck will not start :confused:, ran diagnostics, they are clean. After a playing with it a bit can get it to run as long as you keep the gas pedal down. and after a few hours it runs again fine until...we fuel it again then it wont start, First 2 times it was on an empty tank , last time was on 3/4 full tank. I am thinking fuel filter...but its shot in the dark, any help or suggestions would be appreciated.
  2. Sep 16, 2012 at 9:10 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Welcome to TW. Are the vents blocked or bent?
  3. Sep 16, 2012 at 9:11 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Little more info here does it crank what mods have you done. Any accidents
  4. Sep 16, 2012 at 9:12 AM
    BAMFTACO
    Juan
    Kings bruh
    And welcome op
  5. Sep 16, 2012 at 9:16 AM
    Large
    Large Red
    Could be a fuel pump / filter issue.
  6. Sep 16, 2012 at 9:27 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    No mods, no accidents, just after fuel otherwise it runs fine, i am planning to replace the fuel filter before the next refuel to see if thats it. I do not see any crack, bends or obstructions to the air flow..it only happen after fueling, and then will run great until i fuel it again,
  7. Sep 16, 2012 at 9:28 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    thank you everyone for the welcome aboard :)
  8. Sep 16, 2012 at 9:32 AM
    Artillery68
    Artillery68 Well-Known Member
    Bob
    Gloucester Co., N.J.
    2012 DCSB Super White Sport
    Rugged Cover tonneau, In channel vent visors, Hose clamp tailgate mod, Pop-N-Lock, Fog lights anytime, de- badged/removed graphics, TRD shift knob, OEM bed mat, trimmed all 4 mud flaps, LEDs in
    Welcome from N.J., hope the filter solves your problem. :wave:
  9. Sep 16, 2012 at 9:36 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Do you fill it till it clicks? and it doesnt start? can you fill it to half tank and it starts fine? So as i understand it only doesnt start properly when the tank is completely full?
  10. Sep 16, 2012 at 9:36 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    Does it run better after some time after refuel? Yes it runs fine once we get it running again.
    How low do you let the fuel get when refueling? first 2 times it happend tank was close to E, last time over 3/4 full
    Does it get better when the engine cools down? i think letting the engine cool off helps it but just guessing
  11. Sep 16, 2012 at 9:40 AM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    check the filter definitely you should get in the habit of filling up @ 1/4 tank. If you run it near empty it will suck in all the crap thats in your tank possibly clogging it. Not saying this is your issue but definitely good to do.
  12. Sep 16, 2012 at 9:40 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    I didnt really think to try and fill it part way, may give that a shot and see what happens....only fill it til the first click, then again my wife may be trying to over fill it. On my way to get the fuel filter i may try to put a few gallons in to see if it stalls...thanks for the welcome Artillery68 , Philly transplant here...miss the Shore..:)
  13. Sep 16, 2012 at 10:00 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    Thanks Idaho, trying that now...how would do a fuel pressure leak down test..?
  14. Sep 16, 2012 at 10:17 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    took the gas cap off started just fine.
  15. Sep 16, 2012 at 10:33 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    its running now, going to let it run for 5 and see what happens.
  16. Sep 16, 2012 at 10:38 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    run like a champ..
  17. Sep 16, 2012 at 11:10 AM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    going to try the fuel filter...will post what happens
  18. Sep 16, 2012 at 1:32 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Fuel pump overheated since the tank run to empty. The fuel cools the pump and when empty runs hot. Next time it does this smack the bottom of the tank near the pump area with a rubber hammer. I bet the fuel pump is on its way out.
  19. Nov 14, 2012 at 1:28 PM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    UPDATE, After running pretty good for 2 months car started stalling again, and now will not start at all unless i keep my foot on the pedal, and the check engine light is on,Do not know the codes but will soon , my guess is the fuel pump, can anyone help me to a pressure test on teh fuel system?
    -replaced the fuel filter(pain in the A$$)
    -replaces MAP sensor
  20. Nov 14, 2012 at 4:07 PM
    mactruckx2
    Mac
    San Diego
    02 Tacomma
    Sound System
    Code is P0136, will this cause my truck to stop starting?
