Truck won't start after head unit replacement. *** solved ***
Discussion in '3rd Gen. Tacomas (2016-2023)' started by psvines, May 23, 2024.
  1. May 23, 2024 at 7:01 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    is the key light flashing with the key in?
  2. May 23, 2024 at 8:02 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check the ECU-IG No 2 (7.5A) and ECU-ACC (7.5A) fuses in the interior fuse box for power on both sides with the key on.
  3. May 23, 2024 at 8:38 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Fuse is suspect. Did you say you put factory unit back in to test?
  4. May 24, 2024 at 4:19 AM
    psvines
    psvines [OP] Well-Known Member
    2016 SR5
    All fuses ok and OEM was reinstalled.
    I checked all the little fuses in both places, those that can be pulled with the fuse grabber. Wasn’t sure how to check the large square fuses.
  5. May 24, 2024 at 4:33 AM
    psvines
    2016 SR5
    ECU-IG NO 2 Is 12+ and less than 1.
    ECU-ACC is 12+ both sides
  6. May 24, 2024 at 4:36 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So ECU-IG No 2 is blown.
  7. May 24, 2024 at 4:38 AM
    Ronk44
    Rockerville, SD
    2017 MGM Sport
    You may have to take the truck somewhere to have somebody that troubleshoots electrical issues go through it. Reason I asked about fuses is when I had my OTT tune installed, the installer spent some time troubleshooting my systems because he could not initially flash the factory computer due to communication errors he said were being caused by my after-market Sony head unit interfering with his laptop connected to the dash port. He pulled a fuse or two from under the hood that isolated the head unit circuit completely, and he was then able to factory update computer and install the OTT tune flash update. All worked fine on truck with Tune updates and Sony head unit without communication errors. This is why I knew about these fuses.
    4x4spiegel likes this.
  8. May 24, 2024 at 4:40 AM
    psvines
    2016 SR5
    Meaning? (novice here)
  9. May 24, 2024 at 4:41 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It's bad, replace it with a new fuse of the same rating.
    Stevie17 likes this.
  10. May 24, 2024 at 4:48 AM
    psvines
    2016 SR5
    I don’t follow. I pulled the fuses and checked voltage on each side. The fuse wasn’t installed when checking voltage. Continuity on fuses is good.
  11. May 24, 2024 at 4:50 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No you need to check voltage on both sides of the fuses with them installed and the key on.
  12. May 24, 2024 at 4:50 AM
    psvines
    2016 SR5
    Interesting. I have the kdmax tune. But the no start remains with no radio, or either the OEM or Alpine.
  13. May 24, 2024 at 4:53 AM
    psvines
    2016 SR5
    How is that done? Where to put the multimeter probes?
  14. May 24, 2024 at 4:56 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Blade fuses have test points on them, put one of your probes to ground and the other to one of the test points of the fuse.
    mic_sierra and Stevie17 like this.
  15. May 24, 2024 at 5:13 AM
    #35
    psvines
    2016 SR5
    Wow, never knew that. Thanks.
    All 4 test 12.5v
    gotta run now, on the road until late afternoon. (Obviously not in taco)
  16. May 24, 2024 at 6:00 AM
    #36
    twtaco$
    twtaco$ Well-Known Member
    I wired something to the inj fuse once and blew the fuse it would turn over but not start up. Key start. Look at all the under hood inj, efi fuses. Put a known good fuse in try and start it if it doesn’t swap that fuse back and do the same with the next. Try again.
  17. May 24, 2024 at 6:41 AM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Ok, when you get back to it go back and do the CAN voltage checks I listed in Post #17 and let's see where we sit there.
  18. May 24, 2024 at 6:43 AM
    #38
    81shark
    81shark Well-Known Member
    did you cut wires
  19. May 24, 2024 at 8:18 AM
    #39
    psvines
    2016 SR5
    Nothing cut.
  20. May 24, 2024 at 12:06 PM
    #40
    psvines
    2016 SR5
    What's the key light?
