Truck won't start after head unit replacement. *** solved ***
Discussion in '3rd Gen. Tacomas (2016-2023)' started by psvines, May 23, 2024.
  1. May 24, 2024 at 12:07 PM
    #41
    psvines
    psvines [OP] Well-Known Member
    2016 SR5
    voltage
    4 - 14 is 2.42v
    6 - 14 is 9.8v
    sure glad someone understands this stuff. :)
  2. May 24, 2024 at 12:13 PM
    #42
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    The red light above your air-conditioning controls.
    Blinking stops when the key is inserted into the ignition. If still blinks, the key is not recognized by immobilizer
    Chew likes this.
  3. May 24, 2024 at 12:20 PM
    #43
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Are you certain you were on the right pins? Those readings don't seem plausible.
    Chew likes this.
  4. May 24, 2024 at 12:43 PM
    #44
    psvines
    2016 SR5
    voltage
    4 - 14 is 0.6mV
    6 - 14 is 180mV
  5. May 24, 2024 at 12:48 PM
    #45
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    :confused: I'm confused, are those key on readings?
    jmneill likes this.
  6. May 24, 2024 at 12:49 PM
    #46
    psvines
    2016 SR5
    ah, that light!
    Yes, it blinks until I insert the key and then it stops blinking.l
  7. May 24, 2024 at 1:03 PM
    #47
    psvines
    2016 SR5
    I'm confused too....
    With key ON:
    4 - 14 2.42v
    6 - 14 180mv
    a mixture of earlier readings.
    A hosed ECM? But first test don't guess! Love it.
  8. May 24, 2024 at 1:15 PM
    #48
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Why are we checking 6 -> 14?
    Pin 6 is CAN High, Pin 14 is CAN Low.
    Why are we not checking Pin 4 to 6
    And Pin 4 to 14
    I believe we need to see around 2.5v on each.
    A little more on Can H, and a little less for Can L. But around 2.25-3V is "close"
    Key in ON position when reading....
    Stevie17 and Dm93 like this.
  9. May 24, 2024 at 1:17 PM
    #49
    TnShooter
    Deogee
    STOCK
    If true, This puts you close to the 2.5v.
    as the difference is 180mv....
    2.42+180mv = 2.6ish volts on CAN H.
    Stevie17 likes this.
  10. May 24, 2024 at 1:25 PM
    #50
    TnShooter
    Deogee
    STOCK
    I might have missed it, but with key ON, does the CEL come on?
    It should, with key in the ON position.
  11. May 24, 2024 at 1:31 PM
    #51
    psvines
    2016 SR5
    Key ON
    4 - 6 2.6v
  12. May 24, 2024 at 1:34 PM
    #52
    psvines
    2016 SR5
    With key ON, there are NO symbols lit on either side. No CEL.
    Currently there is no radio installed, just a bunch of wiring harnesses hanging out
  13. May 24, 2024 at 1:36 PM
    #53
    TnShooter
    Deogee
    STOCK
    As expected. ;)
    And.....Now we are on to something.
    We have issues, major issues.
    Kind of like to know what is unplugged.
  14. May 24, 2024 at 1:40 PM
    #54
    TnShooter
    Deogee
    STOCK
    @psvines
    Just to be clear.
    We have NO lights illuminate on the dash with key turned to the ON position?
  15. May 24, 2024 at 1:50 PM
    #55
    psvines
    2016 SR5
    Yes, NO lights with ON key. (except the middle section showing door ajar and odometer)
    Also, fuel gauge doesn't move. Can't recall if it should.
    And I installed the OEM radio, get same voltage readings.
    4-14 2.42v
    6-14 180mv
    4-6 2.6v
  16. May 24, 2024 at 1:59 PM
    #56
    TnShooter
    Deogee
    STOCK
    Ok. Just because we can.
    Check both sides of the 7.5A METER Fuse.
    Let's go from there. As that fuse is tied to another (main fuse).
    But lets start simple.
    Again check both sides of the 7.5A Meter fuse for 12v.
    Key in ON position.
  17. May 24, 2024 at 2:11 PM
    #57
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So our CAN bus seems to be good, I think we need to go back to fuses.
    I'm not at my PC to look at diagrams and get a full list of fuses to check, maybe @TnShooter will in the mean time.
  18. May 24, 2024 at 2:13 PM
    #58
    TnShooter
    Deogee
    STOCK
    If we test the 7.5A Meter fuse, and it has power. We just checked 3 fuses, a relay, a ground and wire integrity, - all at once.
    There is a method to my madness.... :rofl:(sometimes)
    Stevie17 and Dm93[QUOTED] like this.
  19. May 24, 2024 at 2:22 PM
    #59
    psvines
    2016 SR5
    Key ON.
    2.4mv on both sides of METER. Checked many times.
    And fuse looks good, continuity works.
  20. May 24, 2024 at 2:27 PM
    #60
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I like it, I tend to overcomplicate things and go down a rabbit hole sometimes.
    Stevie17 and TnShooter[QUOTED] like this.
