Truck Won't Start After Rain? WTF?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Razorback, Jan 13, 2013.
  1. Jan 13, 2013 at 8:36 PM
    Razorback
    Razorback [OP] Active Member
    Andrew
    Rhode Island
    '13 SR5 4x4
    Not really sure why, but sometimes my truck has a hard time starting after it gets rained on. For example, a couple months back after a 3 hour rain storm, I tried to start her up and the engine cranked, but it just wouldn't turn over. This morning, after an all-night ice storm, same story. Quick details, bought my 04 with less than 50000 miles a couple months back, and the guy who had it before me was an older gentleman who didn't drive it very much. Maybe a spark plug or cable issue?
  2. Jan 13, 2013 at 8:39 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Might be a coincident.
    If its having a hard time starting up that sounds like the starter might be going. Sometimes moisture can effect the contacts in the starter. Either that or the fuel pump might be going too.
  3. Jan 13, 2013 at 8:40 PM
    Domreis
    Domreis Well-Known Member
    Pullman
    My guess would be the temperature causing you grief rather than the rain. Possibly could be the plugs. Plugs should be replaced every 30k, so if you haven't done it yet I would consider it.
  4. Jan 13, 2013 at 8:41 PM
    Domreis
    Pullman
    Would it be the starter if it cranks? Fuel pump is a good possibility!
  5. Jan 13, 2013 at 8:43 PM
    JRFugitt
    JRFugitt Well-Known Member
    Justin
    Texas
    '13 PreRunner V6
    I think it's the temprature. My '13 with less than 1200 miles doesn't like starting in the cold. It cranks at full speed but just doesn't want to light off. I bet it has something to do with etanol content/water saturation in our fuel.
  6. Jan 13, 2013 at 8:48 PM
    Razorback
    Andrew
    Rhode Island
    '13 SR5 4x4
    Any way it could be a leaky distributor cap? A buddy thinks that might be the problem.
  7. Jan 13, 2013 at 8:50 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Do you have a 4cyl or V6?
    V6 dont have dist. caps, they have coil packs
  8. Jan 13, 2013 at 8:55 PM
    Razorback
    Andrew
    Rhode Island
    '13 SR5 4x4
    Well, that answers that question...v6.
  9. May 12, 2014 at 5:37 AM
    LoneCynic
    LoneCynic Well-Known Member
    Ohio, USA
    NBM Tacoma 4x4 TRD Off Road & Towing
    SmittyBuilt Side Steps, DeeZee Bed Mat, TRD Shift Knob, Pop & Lock Tailgate lock, Stantz Locking Gas Cap, Marshall Instruments Oil Pressure & Oil Temperature Gauges
    I am having a similar problem, but mine is a 2nd gen. Although mine does not seem to be temperature related at all. Having gone through a rough winter, my 2013 Tacoma never failed to start or had any issues at all in cold temperatures. Yet now, mid-May, nearing summer, we are in the heavy rain season in my region. Following harsh rain storms, my Tacoma exhibits similar symptoms as described by others. It ramps up when the key is turned, but struggles to turn over. During days in dry weather, it has no issues at all, only directly following intense rain storms does it struggle in any way. It has roughly 18k miles on it currently, so it is still a ways off from any regular maintenance part replacements.
    Is there anything under the hood that is exposed to moisture that shouldn't be? Mine is the 4.0, TRD Off Road with towing package. Anyone discovered the cause of this yet? If so, perhaps we can cover or add something to protect whatever it is that is exposed to moisture, and causing this problem?
  10. May 12, 2014 at 5:57 AM
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Water sitting on top of the spark plugs shorting out the COP's? Pull one of the COP's and see if you have any water in there. If so, blow it out with a compressor or hairdryer and use some dielectric grease.
    Its possible the humidity from the rain is condensing just enough to cause problems.
  11. May 12, 2014 at 1:21 PM
    TheTimmyJimmy
    TheTimmyJimmy Dumbazz
    Tim
    Colorado
    04 Tacoma DBl Cab
    Lots of lil stuff
    Meh?
    The problem you are having is caused by a defective wiring harness and ground point location Toyota technical service bulletin (TSB) # EG042-04 states: Some 2003 -- 2004 model year Tacoma (V6) vehicles may experience an intermittent
    extended or “hard” engine cranking at start up. A revised engine wire harness and ground point relocation is required to correct this condition. APPLIES TO: 2003 - 2004 model year Tacoma vehicles equipped with 5VZ-FE (V6) engines.
