Truck won't start, but will turn over
Discussion in '4 Cylinder' started by hawkeyefan, Feb 7, 2014.
  1. Feb 7, 2014 at 2:40 PM
    hawkeyefan
    hawkeyefan [OP] Member
    Ben
    Fort Riley, Kansas
    1995 Toyota Tacoma
    I posted a few months back that my truck was having some problems starting. After putting in a new fuel pump (which I screwed up the float on because now my gas guage doesn't work), new plugs and wires, new ignition coil, and a new starter my truck still won't start. I had taken it to a shop to get it running and they just replaced what they called "bad parts" ie: the ignition coil and plugs. Just recently my truck will crank but it will not start. The motor sounds like it wants to fire, but it just stalls out while trying to start it. After putting over a grand into this truck I finally had it and had it towed to a toyota dealership. The called me and told me they think that the timing chain may have jumped time. They said for them to check would be about a 6 hour job, and if it did it would take about 16 hours to complete and quoted me close to 3200 bucks. Is this a common issue with the 2.7L or is there something else that could be wrong. I am not paying for that fix if anything I might look for a used motor which would be cheaper. I am just looking for some advice, past experiences, and help!
  2. Feb 12, 2014 at 12:18 PM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    I'm assuming you have solid lifters. They must have a gap for valves to close for compression & power. When parts won't fix have that checked.
  3. Feb 12, 2014 at 12:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think Ben and the truck are gone but I'd look at the ignition module and fuel pump relay. I don't know. Maybe a crank sensor. I assume the truck ran before this. Check all the ground wires aren't corroded off.
