Truck won't start. Everything else lights up
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LadyBallesta, Oct 4, 2023.
  1. Oct 4, 2023 at 10:01 AM
    LadyBallesta
    LadyBallesta [OP] New Member
    Victoria
    2017 Toyota Tacoma SR
    My truck won’t start! Went to store. Locked it. Came back out, inserted key into ignition and truck wouldn’t start. EVERYTHING ELSE LIGHTS UP AND WORKS. The light blinks until the keys inserted, but won’t start.
    buckhuntin-tacoma likes this.
  2. Oct 4, 2023 at 10:17 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW! Maybe a bad battery, you try jumping it.
  3. Oct 4, 2023 at 10:52 AM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Auto or manual?
    If auto, are you sure it's in Park?
    Chew likes this.
  4. Oct 4, 2023 at 11:02 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    How old is battery?
    Start with attempting to have it properly jumped.
  5. Oct 4, 2023 at 11:39 AM
    CT Yankee
    CT
    ^^- Could be this. Battery may have enough "juice" for the lights but not enough to crank it.
    Chew[QUOTED] likes this.
  6. Oct 4, 2023 at 11:42 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I think we’re both on the right track!
    KISS is best starting point, no need to dive in to the bowels of the security system right away.
  7. Oct 4, 2023 at 1:33 PM
    Yoda_Mike
    Yoda_Mike YotaWerx Authorized Tuner
    Michael
    South Glens Falls, NY
    2019 Tacoma TRD Sport
    YotaWerx Blackhawk 2.0 tuned. Typer Auto tail light guards. Rough Country tri-fold tonneau cover. Start-X remote starter. Injen CAI. MBPR Armor Plus high clearance exhaust.
    As noted by others, this is more likely a battery issue. If recall correctly, and Toyota started with a key not registered to the immobilizer ECU will crank normally. It just won't fire because the immobilizer cuts off the fuel and spark. Plus the indicator light would not go out.
  8. Oct 5, 2023 at 4:19 PM
    thrasherpass
    thrasherpass Ham Radio Operator (KM6KXX)
    Logan
    Northern California
    2013 Tacoma 2.7L Base RWD Access Cab Magnetic Gray
    235/75 R15 Cooper Discoverer All-Terrain tires Pro Comp 3 inch leveling kit 3rd gen TRD LED Fog Light upgrade (also fits 2012-2015 2nd gen models) MagnaFlow Off-Road Pro Catback exhaust Body Armor 4x4 Hi-line winch bumper with Badland ZXR 12000 winch Blazer 20-inch spot/flood combo light bar ROADSHOCK 3-inch flood with side lights Wolo musical air horn that plays Tequila by The Champs CB and Amateur Radio equipped: -Uniden Bearcat Pro505XL CB radio with K30 mag-mount antenna -QYT KT8900 2m/70cm ham radio with Nagoya UT-72 mag-mount antenna
    Is the starter cranking, clicking, or nothing at all? Personally I'd check the battery voltage and try cleaning the contacts if its not cranking.
