Truck won't start, good battery - no power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NINETY2, Aug 28, 2014.
  1. Aug 28, 2014 at 5:02 PM
    NINETY2
    NINETY2 [OP] Active Member
    Edmonton, Alberta
    06 DCLB TRD Sport
    OME 3" Lift (885, CB Drop, 2" non-TSB AAL) BHLM Debadged Tint allround
    2006 4.0 v6 dclb
    Came out of the store, and nothing, no power, no lights came on or anything. Assumed it was a dead battery, got a jump off a guy, and it finally turned over and started after many attempts (10mins). Turned my headlights on for the drive home and it cut out my radio, so i turned both off to play her safe. Got home and shut her down and again wouldn't turn over. Then tried getting jumped again but this time it would only make the lights come on/radio etc. but when I tried to turn it over it would click and shut off - then no power at all when the key is in the ignition. Volt meter says 12 volts on the battery, and it's for sure getting 12 volts when jumped, but still for some reason no power. Didn't have any signs of a weak alternator, but maybe? Right now, when it gets boosted, almost 80% of the time there is zero power when the key is in the ignition, then everyone once in awhile it will all turn on to the point of ignition but when I try. Just click and it all dies. I'm going to check fuses now, any thoughts would be greatly appreciated, as I'd hate to have to take it to a shop.
    Side note- I lost my gas cap about 500kms ago.. Doubt it has any thing to do with the problem.
    Thanks!
  2. Aug 28, 2014 at 5:09 PM
    BigBird
    BigBird Paddock Rat
    Michael
    S.F.Bay Area
    Prerunner
    Check your battery grounds.....
  3. Aug 28, 2014 at 5:20 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    Your battery probably has a bad cell. That's why jump starting it doesn't work. It needs to be load tested just to make sure. It can show 12V but still be defective.
    DGXR, cmoore and 06Tacooo like this.
  4. Aug 28, 2014 at 5:22 PM
    TacoLlama
    TacoLlama Well-Known Member
    R.I.
    2019 SR5 DCSB
    have someone hold it in the crank position while you wiggle the ground cables and ends.
  5. Aug 28, 2014 at 5:25 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    how old is the battery?? these new ones just QUIT fast.
    one day OK-next day-nothing.
    Blockhead likes this.
  6. Aug 28, 2014 at 5:32 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    A good battery should read more than 12 volts. Closer to 13 and around 14 when charging.
  7. Aug 28, 2014 at 5:33 PM
    BigBird
    BigBird Paddock Rat
    Michael
    S.F.Bay Area
    Prerunner
    10620538_772833596091775_181222432943074_fdb7a02bc3449a07b2964f6a609db418022ce515.jpg
    DGXR likes this.
  8. Aug 28, 2014 at 6:02 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    Dead battery. I just replaced mine today with a Sam's Club 27F Energizer battery for $99 3yr free replace. Had the True Start in there. Lasted 2 years and 3 months (dealers only warranties @ 24 months).
    Mine wouldn't take a jump either. Good one second...dead the other.
  9. Aug 28, 2014 at 6:59 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Sounds like the battery. Most parts store will test them for free.
  10. Aug 28, 2014 at 7:04 PM
    Bandrews212
    Bandrews212 Active Member
    Bryce
    Northern California
    08 DCSB SR5 4x4
    GoRhino Dominator II steps, Debadged on tailgate, blacked out side badges, Coverking Seat Covers, Weather Tech Wind Deflectors, Pioneer head unit, Retrofits by ambiguous, LED Dome, Maps, and Fogs, Ultragauge, Satashi Grill
    Had a similar problem when I first got my truck. Everytime I turned the key to the on position it would just click and not even turn over. I could jump start it but sometimes that didn't even work. Tested battery, alternator, and starter and all were at 100%. Mechanic said it sounded like the starter was dying. They replaced the starter and it's worked fine for the last 6 months no problems.
  11. Aug 28, 2014 at 7:59 PM
    NINETY2
    Edmonton, Alberta
    06 DCLB TRD Sport
    Sorry I should have mentioned
    Battery is decently new
    It's a 6-7 month old optima red top, voltmeter actually read 12.94v.
    All the fuses seem just fine.
    I go over after it not working at all, and somehow it had a charge to turn the lights on, but again I try and click and dead. Then no power.
  12. Aug 28, 2014 at 8:05 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Get someone to hold the key in the start position while you check voltage at the battery posts. Not the cable clamps, the actual lead posts coming out of the battery. Most likely the 12 volt reading you have with no load will drop out to near nothing with the key turned to start. If that happens, dead battery.
    I sold batteries for awhile, the fact that it's near new means nothing. The Optimas and the Exide orbitals seemed to fail a lot compared to normal batteries.
    wilcam47 likes this.
  13. Aug 28, 2014 at 8:13 PM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    Dealer just changed mine, same price, looks like 84 months, Toyota batteries are good batteries
  14. Aug 28, 2014 at 8:32 PM
    asuchemist
    NONE
    Dealer 24 Month free replacement thereafter it is 50% of whatever MSRP they are doing. If you had dealer replace it check Toyota Owners website as they have a $25 rebate.
    My truck is a 2011 and I have went through 2 Toyota True Starts. I live in the AZ desert I have never had a battery last longer than 3 years.
  15. Aug 28, 2014 at 8:45 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    Check the fuses. I had a 2005 civic with a new battery and nothing would turn on, no dashboard, lights, radio, etc. Called a friend, who's a Honda tech, said to pull the battery fuse, check if it is burnt, flick it, and put it back in and, bingo. The car started.
    Mrb1268 likes this.
  16. Aug 28, 2014 at 8:59 PM
    DocD
    Mn./SoCal
    09 access cab
    probley made by the same company, it has been my experience over the years that a battery warranty, really isn't worth much. I hear ya on the heat, I purchased this one (09) In MN, & it will in all probability spend its last days in the desert, like you say, battery life & I suppose tires, will be replaced much sooner
  17. Aug 28, 2014 at 9:01 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I would attempt a new battery, a non AGM at that. Optima's are notorious for giving starting issues down the road after they've been in for a while. If you are still having the issue. It would be wise to strongly suspect the alternator of being bad, assuming all of your connections, both positive and grounds are tight and good to go.
  18. Aug 29, 2014 at 3:51 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +1, not getting the amps to power anything. Seen this happen many times.
  19. Aug 29, 2014 at 6:04 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    12 volts on a battery is not a good battery. It should read around 12.65. Most likely a bad cell. Have it load tested and go from there.
    DGXR likes this.
  20. Aug 29, 2014 at 6:13 AM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    FIXED?????
