Truck won't start, help!
Discussion in '4 Cylinder' started by oliverlove, Oct 27, 2012.
  1. Oct 27, 2012 at 3:26 PM
    oliverlove
    oliverlove [OP] Well-Known Member
    Oliver
    Laguna Vista, TX
    01 SR5 Ext Cab
    Hey guys, I need some help. My 2001 2.7L is giving me serious issues. The truck won't start. This started about a month or so ago, some days it works great, some days it won't.
    Some days when I disconnect the battery I can jump start it, but it wont do anything from its own battery. Other days nothing works.
    This morning, I walked out and it started right up. I shut her down, and tried again. Nothing. I heard a click, and a crackling sound. So I pulled everything I thought it could be and went to Oriellys. They tested the battery, alternator and starter. All came back clean, and good to go. Now I have no idea what could wrong.
    What else could it be?!
  2. Oct 27, 2012 at 3:31 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    maybe a ground issue?
  3. Oct 27, 2012 at 3:32 PM
    Tacoma Mike
    Southern Maine
    Sounds like a starter contact issue or a bad connection.
  4. Oct 27, 2012 at 3:51 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Seems like a dead spot in the starter or a bad wire going from the batter to the starter. Could lead to an intermittent problem like you're having.
  5. Oct 28, 2012 at 8:01 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    If the battery is healthy (not sulfated or low on distilled water) and fully charged, and the charging system is healthy, then check the solenoid contacts, all the electrical connections for corrosion or oxidation, and the starter brushes. If you battery has gone for long periods (over two weeks) parked, the battery could be partially sulfated and the colder temperatures are affecting it's performance. Please see Section 16 in the Car and Deep Cycle Battery FAQ for more information on sulfation.
  6. Oct 30, 2012 at 10:24 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    That crackling sound is unsettling... disconnect the battery (negative connection is the first one taken off and the last one put on) and make sure all the cables and electrical connections are tight... starter, alternator, ground, fusebox, etc.
