truck won't start - jumpstarting didn't work either
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kkarki13, Feb 25, 2022.
  1. Feb 25, 2022 at 3:04 PM
    Kkarki13
    Kkarki13 [OP] New Member
    Kacey
    1999 Tacoma sr5
    Hey all new to the Tacoma world just purchased my first one and when I got home and pulled into the driveway the truck died and won’t start! I tried jumping it and it won’t even turn over even after the truck is off oil light and a/t oil temp light are staying on
  2. Feb 25, 2022 at 3:29 PM
    ijm01PR
    ijm01PR Well-Known Member
    Alex
    Indiana
    01 DC Prerunner (4x4 TBD)
    Ome 881s w/ 5100s and jba ucas 2” pro comp AAL with 5100s in the rear
    Could have blown a fuse. Not sure what it looks like on the 99 but check the fuse for the starter.
  3. Feb 25, 2022 at 4:26 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Are they staying on with the key out? What happens when you try to start it?
    Area51Runner likes this.
  4. Feb 25, 2022 at 4:34 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Could be as simple as needing to clean up the battery terminals.
  5. Feb 25, 2022 at 4:51 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    We need more info.
    Do the lights stay on when you turn the key off?
    does the engine turn over but fail to start?
    do you get a clicking sound when you try to start it but the engine fails to turn over?
    wilcam47 likes this.
  6. Feb 25, 2022 at 5:09 PM
    Kkarki13
    Kacey
    1999 Tacoma sr5
    The lights stay on even if key is out of ignition and will not turn over at all lights are dim inside and even when hooked up to jumpers doesn’t crank at all
  7. Feb 25, 2022 at 5:12 PM
    Matt Sierra
    Matt Sierra Well-Known Member
    NorCal
    2020 TRD Pro MT
    Maggy SC, C4 Overland front bumper
    The dash lights stay on even when the key is out of the ignition? Do you hear a click from the starter solenoid when you try to start it?
  8. Feb 25, 2022 at 5:14 PM
    Sean42
    Sean42 Well-Known Member
    Talk to the guy you bought it from.
  9. Feb 25, 2022 at 5:49 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    If you just purchased this truck, I'd be calling the seller and asking what the #&@^^# is going on with this truck you sold me.
    henryp and wilcam47 like this.
  10. Feb 25, 2022 at 5:54 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Dead cell
    Can't jump start across a dead short.
    Measure the volts at battery terminals with multimeter.
    Should be 12.5+
    Also dead cells won't take charging.
  11. Feb 25, 2022 at 6:05 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Another vote for battery is toast, which also could be your alternator not charging battery
  12. Feb 25, 2022 at 6:12 PM
    Kkarki13
    Kacey
    1999 Tacoma sr5
    Thank you I’ll throw a good battery in tomorrow and see if it does the truck hoping it’s that easy if a fix!
  13. Feb 25, 2022 at 6:17 PM
    e.deCastro
    e.deCastro Well-Known Member
    Eric
    San Diego
    '01 S-Runner original owner
    Exterior TRD 5 Piece body kit Grillecraft grill DDM Tuning HID retrofit Custom etched Lexus HID Projectors Custom two-tone pin stripe by Jprints Chrome Rocker panels Wheels/ brakes 99 Lexus RX300 OEM wheels converted to 3 piece by ChamorroBoy86 Cadillac ATS Brembo 4 piston calipers Cadillac CTS-V Ceramic Brake pads Mitsubishi EVO IV 12.6” rotors provided by BR Autoworks modified by ChamorroBoy86 Subaru WRX STI Stoptech Stainless Steel brake lines Suspension Custom FBSS air suspension Accu-Rate manifold Dual 444c Viair compressors Accuair Chrome tank Custom Polished Hardlines Streetacos weld on c-notch Custom front shock mounts Custom airbag brackets Streetacos ball joint flip kit Engine TRD supercharger URD 2.2” Supercharger Pulley 312cc NA 2JZ Supra fuel injectors JBA Ti Ceramic Headers Spectre Carb Legal CAI LCE Pro Clutch LCE lightened flywheel 16” electric fan HPS silicone radiator hoses Yellow Top Optima battery Custom Battery tie down Universal oil catch can Denso 105 amp alternator AEM 320 LPH Fuel Pump Interior 02 Lexus SC430 trispoke woodgrain Steering wheel Japanese Rose Wood dash kit Authentic JDM Tsurikawa Nishijin Sakura Gold Black (heart version) Authentic JDM Suichuuka shift knob Authentic Junction Produce Fusa Authentic Junction Produce seat cushion Authentic Influenced VIP satin Pillow set Broadway mirror Custom Aloha print door jamb decals from BigHeadzdesigns LCE Short shift kit Electronics Soundstream VRCP-65 Double Din Multimedia entertainment center Alpine MRV-F545 4-channel amplifier Alpine MRD-M1005 monoblock amplifier NVX VCW124 12” Subwoofer MB Quart DSH216 6.5” 2-way component speakers Black Vue 650S Front and Rear Dash Camera AEM boost gauge AEM Uego wideband O2 controller URD Mass Air Flow Fuel and Timing calibrator
    I would check the voltage first. No use on buying a new battery if it’s not the problem. Do you have a meter?
    0xDEADBEEF likes this.
  14. Feb 25, 2022 at 6:25 PM
    Matt Sierra
    NorCal
    2020 TRD Pro MT
    Assuming you have no luck with the guy who sold it to you and don’t have a multimeter, a lot of parts shops will do a battery/ charging system test for free.
  15. Feb 25, 2022 at 7:20 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    This. And even if you see 12.5+ it doesn't mean it can provide the amperage requirement.
    If it isn't that...suck, squeeze, bang, blow. Which one is missing?
    But this sounds like a classic case of a battery that has been deep discharged a few times and can't provide the proper juice anymore.
    On another note: Priced a battery recently? Damn. Check Costco. They have a nice AGM for our trucks at about $160.
  16. Feb 26, 2022 at 2:48 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Price of batteries and tires is way up. Was that your first ride in your new truck.
  17. Oct 18, 2024 at 7:03 PM
    leofrasson
    leofrasson Member
    Leo
    2011 Green Tacoma
    Hey everyone! I'm dealing with a similar issue. My truck won’t start, even after trying with jumper cables and connecting a new battery—still nothing. I ran an OBD2 scan, but no codes showed up. To top it off, my honk stopped working a few days ago. Any ideas on how I can get my truck back to life? Thanks in advance!
  18. Oct 18, 2024 at 7:13 PM
    MadNachos
    What is the voltage on your battery at rest?
    Not all jumper cables are up to task so that can be a factor.
  19. Oct 18, 2024 at 7:17 PM
    leofrasson
    leofrasson Member
    Leo
    2011 Green Tacoma
    I haven’t tested it yet, but tomorrow morning I’ll head back with a multimeter and a few extra fuses.
  20. Oct 18, 2024 at 7:19 PM
    DoktorSlowburn
    DoktorSlowburn Well-Known Member
    Escondido, CA
    1997 White Tacoma SR5
    4runner seats and center console, ARB rear locker, Icon 1.5” AAL, Bilstein 5100 on 4th notch in front (to support future tube bumper & future winch), 4600s in the rear. In-Cab CB radio. Hella 500 Driving lights. All-Pro Baja front bumper.
    Check the 80amp big fuse in your engine bay fuse box. This happened to me just yesterday when I was doing dumb shit under the hood.
    I found out after breaking it trying to yank it out that it’s bolted in from the bottom side of the fuse box.
