Truck wont start. Only clicking noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MS98, Jan 13, 2015.
  1. Jan 18, 2015 at 5:57 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Truth ... A little corrosion + cold temp will take you out of the game. I use this kit from WallyWorld on all our vehicles and it keeps me trouble free with regards to corrosion. Might be worth a shot before replacing that connector. :notsure:
    EDIT: some odd comments about a 50ct kit online ... Don't buy it online ... It's available in store last I checked. Each kit has the two pads and little can of spray corrosion preventative.
  2. Jan 18, 2015 at 5:57 AM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    This^ X2. IF you have a starter contact issue, then the starter may have just decided to work at that point regardless of the battery jump. If its the starter sometimes it will turn, sometimes it wont. If it was a "BUZZ" most likely battery. If it was more of a "Click" starter contacts. Just my opinion.
  3. Jan 18, 2015 at 6:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yep. If the battery tested good with a proper load test (different than 'charged fully'), then something drained it while you were in school.
    Lots of other ideas tossed out here are worthy of attention, but always start simple and cheap.
    I've jumped lots of batteries that have given good service for a number of years after. Usually because I made a mistake with some type of load, or someone previously messed up wiring somewhere, creating dark current. Usually a stereo or alarm install.
    It could be the battery is tooting it's last. Or not.
  4. Jan 20, 2015 at 7:52 AM
    beeesmitty
    beeesmitty Well-Known Member
    NC
    11' SR5 DC BSP 4X4
    265/75/16 Cooper ATP, TRD FJ Trails, 5100's @ 2.75, ReadyLift 2" Blocks
    I do not.
  5. Jan 20, 2015 at 8:07 AM
    Yakoma
    Yakoma Well-Known Member
    Randy
    ATL-ish
    '14 DCSB TRD Sport 4x4 - White
    Black APS Bull Bar Black Westin Step Bars Black ARE camper top with Yakima J-cradles (replaced Roll-X Tonneau) Black AMP HD Bed Extender
    OK...OP, what was the answer? Or are you still walking to school?
  6. Feb 26, 2015 at 4:24 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Bump...
