Truck won't start properly after K&N filter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kiwiman808, Dec 5, 2021.
  1. Dec 5, 2021 at 6:38 PM
    Kiwiman808
    Kiwiman808 [OP] Member
    Jules
    2019 Tacoma
    Aloha, so i installed a K&N filter today . I didn't disconnect the battery ( instructions said to) the truck will start then dies. I took off air sensor and it runs.... Any ideas ?
  2. Dec 5, 2021 at 6:41 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    vitistop and buckhuntin-tacoma like this.
  3. Dec 5, 2021 at 6:43 PM
    LanceRN
    LanceRN Well-Known Member
    Lance
    1998 Purple Tacoma TRD
    Was this a cold air kit, or just a replacement filter?
    CygnusX191 likes this.
  4. Dec 5, 2021 at 6:44 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Dec 5, 2021 at 6:45 PM
    Kiwiman808
    Jules
    2019 Tacoma
  6. Dec 5, 2021 at 6:46 PM
    Kiwiman808
    Jules
    2019 Tacoma
    Cold air intake
  7. Dec 5, 2021 at 9:01 PM
    LanceRN
    Lance
    I would recheck everything, particularly the direction the mass air flow sensor is pointing.
    batcat420, Evostaco and CygnusX191 like this.
  8. Dec 5, 2021 at 9:05 PM
    Bishop84
    Bishop84 Well-Known Member
    Air meter is backwards.
  9. Dec 6, 2021 at 12:27 PM
    Kiwiman808
    Jules
    2019 Tacoma
    Thank you so much sensor was wrong direction!!Reall appreciate your help Aloooooha
  10. Dec 6, 2021 at 8:37 PM
    LanceRN
    Lance
    Nice, easy fix.
    DAS Taco and CygnusX191 like this.
  11. Dec 6, 2021 at 9:01 PM
    Kiwiman808
    Jules
    2019 Tacoma
    Felt like a jackass but thanks…
    Gotta pretty sweet 2019 Tacoma pics will come
    604 and CygnusX191 like this.
  12. Dec 6, 2021 at 10:38 PM
    LanceRN
    Lance
    All good, live and learn. Didn't hurt anything but your pride, lol.
  13. Dec 6, 2021 at 11:29 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I'd still disconnect/reconnect the battery to let the ecu relearn it's newfound airflow. Might not be necessary, but it might be.
  14. Dec 6, 2021 at 11:39 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    Enjoy your new intake system! :thumbsup:
  15. Dec 7, 2021 at 6:01 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I had constant issues with a trd pre oiled k&n air filter when i installed one on my 4.7 tundra. It kept fouling the mass air sensor. I'd have to remove it to clean the k&n oil filter residue from it. Finally had enough, and put a wix paper filter back in. Never another problem.
    Taco_mike73 and CygnusX191 like this.
  16. Dec 7, 2021 at 6:06 AM
    Red Five
    Red Five Well-Known Member
    Texas
    2021 TRD Off-Road manual transmission
    Same thing happened to me several years back with my first gen Raptor. Was so excited after installing my S&B intake but the thing would stop running about a second after starting the truck.
    Just as I was dejectedly walking back into the house a lightbulb came on and I flipped the sensor, started the truck, danced about as well as Elaine Benes, and hoped nobody saw any of that.
  17. Dec 7, 2021 at 6:15 AM
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    :rofl:
    Oddly enough, I've never had fouling issues on my maf with oiled filters. I'm about due for a good filter cleaning though....
    DAS Taco and Junkhead like this.
  18. Dec 7, 2021 at 7:39 AM
    zoo truck
    None
    Friggin engine light kept coming on when the maf sensor got fouled.
    shakerhood and CygnusX191 like this.
  19. Dec 7, 2021 at 7:45 AM
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    99% of engine lights have to do with fuel/air mixture.makes sense lol
    Junkhead likes this.
  20. Dec 7, 2021 at 11:17 AM
    zoo truck
    None
    Yep, yet it was stated in my owners manual that the TRD K&N air filter was an option that could be used. This air filter likely came oiled to much. I probably could of bought the cleaning, and re-oiling kit to fix the issue, but ended up buying a cheaper paper filter. What i've learned over the years is to replace stuff with what came in the vehicle, after all the manufacture did the research already what works best.
    CygnusX191[QUOTED] and Junkhead like this.
