Truck won't start. Rapid clicking noise.
Discussion in '1st Gen. Tacomas (1995-2004)' started by JBF, Sep 7, 2010.
  1. Sep 7, 2010 at 8:31 PM
    JBF
    JBF [OP] Active Member
    2003 PRERUNNER SR5
    Hey all,
    I've got a 2003 Tacoma PreRunner SR5. Has just under 100k miles on it. Never had any problems with it until now. What is happening is that when I try to start it I just hear a loud rapid succession of clicks. The engine doesn't turn at all. As far as I can tell the battery is fine. The lights are dimming when I'm cranking it. Is this definitely the starter or solenoid?
    Hoping to get this figured out! Thanks!
  2. Sep 7, 2010 at 8:33 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    check the battery.
  3. Sep 7, 2010 at 8:33 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    low battery
  4. Sep 7, 2010 at 8:34 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    yep. not enough juice to crank the beast. jump it.
  5. Sep 7, 2010 at 8:34 PM
    pm321
    pm321 Well-Known Member
    X2 ^
  6. Sep 7, 2010 at 8:36 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    No mods whatsoever!
    Sounds like the starter solenoid is bad. I haven't looked at a Toyota starter in some time, but the last I knew that the solenoid is attached to the starter. You can remove the starter and have it checked. If it's bad, I would replace the whole unit for the warranty and peace of mind. Confirm it's not the battery first. Good luck.
  7. Sep 7, 2010 at 8:42 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Test the battery.
  8. Sep 7, 2010 at 8:44 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    yea the battery is dead, if the lights are gettin dim when you turn the key and it wont crank then that is def. the battery.
  9. Sep 7, 2010 at 8:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did anyone mention the battery yet?
  10. Sep 7, 2010 at 8:45 PM
    JBF
    2003 PRERUNNER SR5
    Okay I'll check the batter and get back to you guys. Thanks for the fast responses!
  11. Sep 7, 2010 at 8:48 PM
    98_Mud_bug
    lucedale Ms.
    im not sure.. bump for a response?
  12. Sep 7, 2010 at 9:11 PM
    JBF
    2003 PRERUNNER SR5
    Just tried jumping it. No dice. When I said the lights dimmed I mean just in the normal way that they dim for a second when you start any car. Someone else told me to check for this, though I don't know why. That's why I mentioned it. The headlights shine brightly on their own.
    So where do I go from here, ya'll?
  13. Sep 7, 2010 at 9:11 PM
    98_Mud_bug
    lucedale Ms.
    smack the starter with something. hammer or a wrench or somethin
  14. Sep 7, 2010 at 9:12 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
    Get the starter tested.
  15. Sep 7, 2010 at 9:16 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    x2 its not a joke
  16. Sep 7, 2010 at 9:19 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    battery?...lol
  17. Sep 7, 2010 at 9:21 PM
    JBF
    2003 PRERUNNER SR5
    Okay where exactly do I find the starter (or where can I find out where it is)? And can I do this by myself or do I need to be turning the key while someone else bangs on it?
  18. Sep 7, 2010 at 9:31 PM
    98_Mud_bug
    lucedale Ms.
    lay under the truck and look bolted to the side of your transmission. it looks like a coke can with a little thing hanging on the side of it. ill try to find a picture.
    TOTASTB_e51c807e9e4addf5387b0be34af11cd5796a3ab7.jpg it will look kinda like this
  19. Sep 7, 2010 at 9:42 PM
    JBF
    2003 PRERUNNER SR5
    Okay thanks I'll give it a try.
  20. Sep 7, 2010 at 9:53 PM
    dexterdog
    Oly WA
    2012 F150
    Test the battery. Sometimes it can be too far gone. If it tests out fine then move to the starter.
