Truck won't start up after new radio install
Discussion in 'Audio & Video' started by jarpil, Sep 9, 2012.
  1. Sep 9, 2012 at 3:10 PM
    jarpil
    jarpil [OP] Well-Known Member
    Kalaheo, HI
    2017 Tacoma TRD OR DCSB, black
    So i installed AVIC-z130BT. Everything works as it's supposed to. Did video bypass(soundmancaraudio.com). I checked all fuses(the ones you can see trough) and all are ok. I can hear the starter but engine won't ignite. Any ideas?
  2. Sep 9, 2012 at 3:13 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Drain the battery maybe?
  3. Sep 9, 2012 at 3:15 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    Thats what i was thinking. Did you tune the speakers and everything right after you installed it? Might just have ran the juice out of the battery. Try and jump it
  4. Sep 9, 2012 at 3:17 PM
    jarpil
    Kalaheo, HI
    Well starter is working so battery should be ok, no? Also all dash lights are on that also indicates battery is fine, correct? I had battery disconnected during the install.
  5. Sep 9, 2012 at 3:19 PM
    Blackshirts
    TX
    Stuff
    Check the battery connections...my lights still came on and it would crank but wouldn't turn over. It was a bad cell in the battery straight from the dealer.
  6. Sep 9, 2012 at 3:21 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    Your battery can power those little lights for days. your starter draws way more amps than those lights. Just because your lights are working doesnt mean your battery is good.
  7. Sep 9, 2012 at 3:27 PM
    jarpil
    Kalaheo, HI
    Tried to jump start and it just won't start up. I hear starter but that's it.
  8. Sep 9, 2012 at 7:10 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    fuse for fuel pump go out? do you hear the fuel pump turn pressurize when you turn the key?
  9. Sep 9, 2012 at 8:12 PM
    jarpil
    Kalaheo, HI
    Solved! While i was figuring out which wire to connect the VSS wire to i pulled out the plug and then decided not to connect the VSS but i didn't plug it back in.
    :frusty: :eek:
    Thank you everyone who tried to help.
  10. Sep 9, 2012 at 8:40 PM
    6spd
    san diego
    2023 4x4
    VSS? where was your mishap located?
  11. Sep 10, 2012 at 7:45 AM
    jarpil
    Kalaheo, HI
    Vehicle speed sensor wire. It's behind the glove box.
  12. Sep 10, 2012 at 11:02 AM
    6spd
    san diego
    2023 4x4
    is that wire needed to connect to your head unit?
  13. Sep 10, 2012 at 2:35 PM
    jarpil
    Kalaheo, HI
    Installation manual says it is needed but after some online research i found out it is not required.
