Truck won't start, very sudden, no signs leading up to it. Please help!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by nickuhas23, Jul 16, 2018.
  1. Jul 19, 2018 at 3:12 PM
    nickuhas23
    nickuhas23 [OP] Member
    Nick
    2000 V6 Pre-Runner
    none
    thank you for all of these fixes, I tried the park vs neutral .. nothing
    I've checked the grounds and the fuses.
    I've now borrowed my buddies Diagnostic and ran it on my truck, in the pending code section it said P0340 "camshaft position sensor A circuit bank 1 or single sensor"
    Would this cause the truck to not start (not even turn over)?
    Thank you, everyone, who's helped thus far, it's GREATLY appreciated!
  2. Jul 19, 2018 at 4:06 PM
    Glamisman
    Glamisman Well-Known Member
    from starting yes, from cranking no.
  3. Jul 19, 2018 at 4:11 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Have you tried to jump it? Even if accessories run it doesnt necessarily mean the battery is good. The current required to run lights is a fraction of the current needed to start the truck. If it starts with cables there's a good chance the battery going bad.
    *edit* Missed the part in the 1st post sorry
  4. Jul 19, 2018 at 10:08 PM
    nickuhas23
    Nick
    2000 V6 Pre-Runner
    none
    thanks for the reply, I tested the battery with a voltmeter (showed 12.43) and I test the connection at the starter motor and it was the same (12.43)
  5. Jul 20, 2018 at 12:42 AM
    elduder
    Van WA
    12.43v is starting to get low, if I remember correctly any voltage below 12.4 is considered diminished. With the warm weather though I doubt its the issue, but you may want to get a tender or replace it at some point.
  6. Jul 20, 2018 at 12:59 AM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    What is the voltage at battery when trying to start? It could be 12+ at rest and drop to 4v when trying to start = no good.
    The cam sensor code just means the computer is expecting the engine to be turning when the key is in the START position. You can ignore this until you get the starter to work.
    lvs2rock likes this.
  7. Jul 20, 2018 at 2:44 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    I'll echo this. I thought my battery was fine. Tested over 12v. It worked in the morning but wouldn't start the truck in the afternoon. But it was 9 years old. Changed the battery and problem solved. Costco has our battery for $86. I just checked last week.
    Also, if you have a serviceable battery, add distilled water to the cells. There are videos on this. With the summer heat, lots of evaporation occurs, especially here in the south.
    https://www.wikihow.com/Check-Car-Battery-Water-Levels
  8. Jul 20, 2018 at 7:14 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    this has happened to me too, they read the CCAs on the battery and it had 8 CCAs left! Battery was absolutely trashed. One moment working, the next moment dead. I was in the process of replacing the starter when I thought, maybe I should change the battery first.
    Benny123[QUOTED] likes this.
  9. Jul 20, 2018 at 7:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I would try another battery
  10. Jul 20, 2018 at 9:57 AM
    Actionjackson
    Actionjackson Well-Known Member
    Jack
    MA
    2004 Tacoma
    A valuable tool for this type of troubleshooting is the battery load tester. I have a cheapie but it works fine and once helped an argument with a parts counter guy over a brand new battery I bought with a shorted cell. Good voltage reading but shot to 0 when the load was applied. This type of tester can be purchased for 25 to 35 dollars. (yes I know it is a cheap POS. but I have found mine very useful)
    Benny123 and lvs2rock like this.
  11. Jul 23, 2018 at 6:37 AM
    Benny123
    Ben
    South Charlotte, NC
    Would love to hear an update on this. Was it the battery?
  12. Jul 23, 2018 at 6:47 AM
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    Some years ago I was returning home from the mountains. I stopped at the gas pump to fill up. My vehicle didn’t start after that. Just like what you where saying, nothing leading up to it. Got a tow home. Opened the hood the next day, ready to replace all sorts of things. Neighbor came over and taught me a lesson. He cleaned the battery terminals and like magic the vehicle started. Drove it for years after that with zero issues.
  13. Jul 23, 2018 at 8:22 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I've had this exact experience with a few vehicles.
  14. Jul 23, 2018 at 8:39 AM
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
    My wife's GMC did this last year. When the motor was cold it would start and run just fine but once it got up to temp it would die. Turned out to be a bad fuse block. The wiring inside tested fine for continuity but found out that if I smacked it with the motor running it would kill the motor also
  15. Jul 23, 2018 at 9:08 AM
    #35
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I might also suggest the ignition switch may be getting worn. Do the instrument panel lights react when you move the key from ON to Start? If you have a helper, you might also use a volt meter and measure at the soleniod when the key is turned to start.
