truck won't start when it's hot
Discussion in 'Technical Chat' started by Beast Mode 808, Sep 15, 2016.
  1. Sep 15, 2016 at 9:50 PM
    Beast Mode 808
    Beast Mode 808 [OP] Member
    1996 Toyota Tacoma 4x4
    My truck starts in the morning. When I leave for work it starts right up. It's when I get home, it'll sit for about 10 min to 15 min. Then I'll try to start it up and it won't start. Changed the fuel filter, spark plugs, coil, air filter. All the small stuff. Love my Tacoma! It has 235000 miles!
  2. Sep 15, 2016 at 10:01 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Is it a crank/no start condition, or a no crank condition.
    How old are your starter and battery. Battery condition (voltage while starting). Use to have that same issue with my Chevy LUV with a 383. Older starter would get hot while driving and couldn't turn the motor over no matter what battery I put in. With my '40, I had some battery issues that caused it not to have enough to turn a hot starter, but did fine when cold or with a jump.
  3. Sep 15, 2016 at 10:03 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Could be fuel injectors. They are known to leak on our older trucks with residual fuel pressure and flood the engine after it has been turned off. Then if you try to start it soon it floods and won't start. If this sounds like the problem I think the pink injectors from 01-04 are supposed to be better, but you should do some searching on the topic first.
    Could be other things too.
  4. Sep 15, 2016 at 10:04 PM
    Ridgeline001
    Ridgeline001 Well-Known Member
    Oregon
    2014 DCLB Sport 4wd
  5. Sep 15, 2016 at 10:08 PM
    Beast Mode 808
    It cranks ok I guess. But I have been told that it might be the mass air flow sensor. What do you think?
  6. Sep 15, 2016 at 10:12 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    Look into what the others said.
    When you crank it hot, can you smell raw gas in the exhaust?
  7. Sep 15, 2016 at 10:31 PM
    Beast Mode 808
    Thanks guys! Ill try cleaning the IAT & the mass air flow sensor. And see what happens. I'll let you guys know. Thanks again
  8. Sep 15, 2016 at 10:34 PM
    Beast Mode 808
    Battery is fairly new. And when I try starting when hot, I do smell gas, while pumping the gas pedal slightly.
