Truck won't start with key, will start if I jump by relay
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bob2025, Oct 1, 2022.
  1. Oct 1, 2022 at 2:48 PM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    I got a problem with my 99 tacoma 4x4 auto 4x4 cant get it to start off the key will start if I jump the relay off but other than that the relay just clicks changed it out with good relays doesnt change nothing
    Black DOG Lila likes this.
  2. Oct 2, 2022 at 10:52 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Load test the battery at parts store
    Area51Runner likes this.
  3. Oct 2, 2022 at 12:43 PM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    The battery is brand new and itall start when I jump it from the relay as long as you got the key on itall start just won't start with a relay
  4. Oct 2, 2022 at 4:08 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Which relay are you jumping, I'm asuming pins 3 and 5 of the starter relay in the fuse box?
  5. Oct 6, 2022 at 4:37 PM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    I changed the fuse box on it now it has no spark
  6. Oct 6, 2022 at 6:32 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    What led you to change the fuse box?
    Which fuse box did you change?
  7. Oct 7, 2022 at 6:17 AM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    It wouldn't start off the key so I changed the whole fuse box and now it has no spark to none of the plugs
  8. Oct 7, 2022 at 8:25 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I think you'll get some more help if you give us some more detail about what exactly you are doing.
    You need to clear up what relay you were trying to jump, which fuse block you tried to replace, and what even lead you to try that.
    Maybe provide what motor you have as well.
    There are a lot of smart folks here, but they need details.
    Dm93 likes this.
  9. Oct 7, 2022 at 8:55 AM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    I solved it I changed the fuse box outside and itall crank off the key but won't get no spark
  10. Oct 7, 2022 at 9:13 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Then check the connections from the relay to the fuel pump.
  11. Oct 7, 2022 at 9:32 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Do you have power at the Black/Red wire (Pin 1) at the ignition coils? If not check your AM2 fuse 30A.
  12. Oct 7, 2022 at 1:43 PM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    It's getting gas just no fire it said it had a igniter coil bad or something
  13. Oct 7, 2022 at 2:28 PM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    It's a code p1300 igniter circuit malfunction no.1
  14. Oct 7, 2022 at 3:13 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you verified you have power at the ignition coils?
  15. Oct 7, 2022 at 9:39 PM
    Bob2025
    Bob2025 [OP] Member
    Zack
    1999 Tacoma
    Yeah there was a ground on the plate that holds the ignition coils on it wasn't snugged up just sitting on it
