Truck Won't Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by db2, Nov 18, 2010.
  1. Nov 18, 2010 at 2:40 PM
    db2
    db2 [OP] Well-Known Member
    2016 TRD Sport DC
    This is more of a solution then a question. I was doing the Inverter Mod, the one that allows for 400w while out of Park, I wired everything up according to the directions I found, but when I went to test it, the switch lit up as expected but the truck wouldn't start. Everything else worked, but when I turned the key nothing...radio turned off but it wouldn't crank. I double checked all my wiring and everything looked fine. I started check fuses under the hood and found the problem. The STA 7.5 AMP had blown. I believe this fuse has something to do with the Electronically Controlled Transmission on the V6 Tacoma. Since the Inverter checks to see if the Transmission is in park before allowing 400w it must be connected to the same Fuse at some point. I must have ground that wire at some point while I was doing the wiring.
    So, here is my suggestion...
    1. Doing electrical work on your truck - disconnect the negative battery terminal.
    2. If your truck won't start - one place to check is the 7.5 STA Fuse
  2. Nov 18, 2010 at 3:24 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Thanks for posting your findings. Hopefully it all works as it should now.
  3. Nov 18, 2010 at 7:11 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    yea, when i installed my remote start i blew that thing a few times till i tracked down my wire problem. Freaked me out at first, glad it was an easy find/fix.
  4. Nov 19, 2010 at 8:07 AM
    db2
    2016 TRD Sport DC
    Yeah - Freaked me out too. I thought I was gonna have to call a tow truck! I had checked and rechecked the wiring everything looked right...but no starting...
  5. Nov 19, 2010 at 8:14 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
