Truck Won't Start
Discussion in 'Technical Chat' started by jonistkrieg, Sep 27, 2015.
  1. Sep 27, 2015 at 8:53 AM
    jonistkrieg
    jonistkrieg [OP] Member
    Jon
    AZ
    10 SR5 Access Cab
    Truck was running fine when I turned it off to do an errand and when I went to start it again, it wouldn't start. Turning the key to on had all electronics working, when I turned the key to start the engine all the electronics shut off. I don't know anything about cars. Has anyone experienced anything like this before?
  2. Sep 27, 2015 at 9:04 AM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    my guess is the battery or the starter, have someone jump start you and get that battery and or starter check out.
  3. Sep 27, 2015 at 9:07 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Same thing happened to our 4Runner, battery still showed 12 volts but it was toast and did not have enough CCA's for the starter to turn the motor over.
  4. Sep 27, 2015 at 9:07 AM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Does it crank or just the electronics come on?
  5. Sep 27, 2015 at 9:19 AM
    jonistkrieg
    Jon
    AZ
    10 SR5 Access Cab
    It was just the electronics and when I turned the key to start, the engine did nothing and then all of the electronics turned off.
  6. Sep 27, 2015 at 9:19 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Just went through this with my '06. It was the battery.
  7. Sep 27, 2015 at 9:22 AM
    jonistkrieg
    Jon
    AZ
    10 SR5 Access Cab
    I just bought a new battery 3 months ago
  8. Sep 27, 2015 at 9:27 AM
    Shelf Life
    Rob
    Central Oregon
    Possible defective battery. Have it tested. It could be as simple as loose terminal connections.
  9. Sep 27, 2015 at 9:31 AM
    jonistkrieg
    Jon
    AZ
    10 SR5 Access Cab
    Orite thanks!
  10. Sep 27, 2015 at 9:44 AM
    POOLGUY
    JEFF
    ALABAMA
    Ok, cause mine sometimes cranks but would not start. I just have to pull the fuel relay and tap it, put it back and it starts like nothing was wrong.
  11. Sep 28, 2015 at 12:49 PM
    jonistkrieg
    Jon
    AZ
    10 SR5 Access Cab
    I went by Orielly today and the guy said it could possibly that my alternator is failing to completely charge my battery.
