Truck wont start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jobani 02 taco, Jan 15, 2016.
  1. Jan 15, 2016 at 10:12 AM
    Jobani 02 taco
    Jobani 02 taco [OP] Active Member
    Jobani
    2002 sr5 4x4
    Truck won't start, not the battery, tried hitting the starter, won't ho into neutral winter he key in the on positions, any thoughts
  2. Jan 15, 2016 at 10:14 AM
    AdamM
    AdamM Semi-pro aardvark wrangler
    Adam
    Edmonton, AB
    14 DCSB base 6MT 4x4
    Do your dash lights come on?
  3. Jan 15, 2016 at 10:15 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    I don't think so
  4. Jan 15, 2016 at 10:16 AM
    AdamM
    Adam
    Edmonton, AB
    If your battery isn't dead, maybe a break in your starter circuit somewhere. Just to be safe, did you try boosting?
  5. Jan 15, 2016 at 10:17 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    How do you know it isn't the battery?
    Dash lights are a fairly large clue.
    Firebird and AdamM like this.
  6. Jan 15, 2016 at 10:19 AM
    AdamM
    Adam
    Edmonton, AB
    Maybe check to make sure your dome light or headlight switch aren't in the on position.
  7. Jan 15, 2016 at 10:20 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    What's boosting I'm a noob, well we connected jumpers to my battery and it sparked, we also junmped it for a bit
  8. Jan 15, 2016 at 10:21 AM
    T4RFTMFW
    Try another battery.
    Report back.
  9. Jan 15, 2016 at 10:21 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    Headlights are off
  10. Jan 15, 2016 at 10:21 AM
    AdamM
    Adam
    Edmonton, AB
    What you did, as long as the jumper cables were connected to a charged battery on the other end...
  11. Jan 15, 2016 at 10:22 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    Also already sapped batteries with a friend
  12. Jan 15, 2016 at 10:23 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    Any other ideas
  13. Jan 15, 2016 at 10:24 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Check the main fuse in the fuse box. The big one.
    Jobani 02 taco[OP] likes this.
  14. Jan 15, 2016 at 10:25 AM
    timothom
    Also, you said you swapped batteries?
    1 - do you dash lights come on when you turn the key the to run? Or is it still stone dead?
    2- When you had it hooked up to another car with jumper cables, did the engine crank at all?
  15. Jan 15, 2016 at 10:26 AM
    T4RFTMFW
    I guess mentioning what you have tried already is a good idea, you didn't mention swapping batteries until 4 people tried helping.
    Anything you know should be said up front otherwise you're wasting our time and we're wasting yours.
  16. Jan 15, 2016 at 10:31 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    Batteries no dead but dash lights won't come on headlights will
  17. Jan 15, 2016 at 10:32 AM
    timothom
    Probably fuse related then. Check your fuses
  18. Jan 15, 2016 at 10:33 AM
    timothom
    Hopefully you have out your owners manual, it will show you were to do this and what fuses control what. Make sure to only take one out at a time. Calm down and do it methodically.
  19. Jan 15, 2016 at 10:33 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
  20. Jan 15, 2016 at 10:41 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    do you have a clean connection from the battery cables to the battery itself. make sure the copper wires arent all gummed up inside the connectors. it sounds to me that either the starter or starter solenoid is acting up.
