Truck wont start
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jobani 02 taco, Jan 15, 2016.
  1. Jan 15, 2016 at 10:44 AM
    Jobani 02 taco
    Jobani 02 taco [OP] Active Member
    Jobani
    2002 sr5 4x4
  2. Jan 15, 2016 at 10:47 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    so recap, its turning over just not starting, the dash lights turn on, stereo, light ect. work is this correct? im having a hard time figuring out whats already been tried.
    also i assume ur an automatic correct?
  3. Jan 15, 2016 at 10:56 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    Key goes in, doesn't click like it usually should, dash lights don't come on, headlights do, won't go into neutral with the key in the on position, tried jumping it, swapped batteries already, and tried hitting the starter
  4. Jan 15, 2016 at 11:04 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    it wont go into neutral? ur an auto correct?
  5. Jan 15, 2016 at 11:04 AM
    Toyko Joe
    Toyko Joe Here for the pictures
    OP,
    Please use whole words. Also, sentences. People generally like to help but if you don't list what you have tried in succession, they are less apt to help.
    If you have an automatic transmission, there should be a manual override for your shifter position behind a small square piece (near the shifter). This should allow you to place the transmission back in Park or Neutral.
    ^ I believe this is shown in your owners manual.
    Get it in Park or Neutral first and try again.
  6. Jan 15, 2016 at 11:11 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    YesGot it, ill get back to you guys when I get to try it
  7. Jan 15, 2016 at 11:17 AM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Could the steering wheel position have any affect on this? You said the key goes in but "doesn't click like it should". Turn the wheel back and forth to make sure the wheel lock isn't engaged- if I remember correctly, this can also affect shifter position/lock.
    Edit: turn the wheel back and forth while giggling the key.
  8. Jan 15, 2016 at 11:28 AM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    I do that every now and then before it's not it
  9. Jan 15, 2016 at 2:42 PM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    It was a relay switch
    timothom and NMTrailRider like this.
  10. Jan 15, 2016 at 5:07 PM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    Thanks for the closure, Jobani. Was it a relay in the fuse box or on the starter or somewhere else?
  11. Jan 15, 2016 at 5:08 PM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    In the fuse box, thanks for everyone pitching in and being patient
    NMTrailRider likes this.
  12. Jan 15, 2016 at 5:09 PM
    timothom
    ain't no thang bro. I know it sucks when these things break. What year is your Taco?
    I was thinking I have a few extra fuses, but I should get some relays too. I go into the back woods sometimes and getting stuck out there like this beacuse of a $4 relay would piss me off :)
  13. Jan 15, 2016 at 5:11 PM
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
    Haha good looking out,yeah especially since its my first car,02, seriously
  14. Jan 15, 2016 at 5:12 PM
    timothom
    Cool beans. Well at least it was a cheap fix, right? Least you didn't have to pony up 5 bills or something
  15. Jan 15, 2016 at 5:24 PM
    #35
    Jobani 02 taco
    Jobani
    2002 sr5 4x4
