Truck won't start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bluecord, Jan 29, 2021.
  1. Feb 4, 2021 at 5:40 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Maybe let gravity assist you and have your front end pointed downhill. This will cause all the ball bearings to roll towards the flex plate. I would then jack up the driver side of the rig so the ball bearings shift towards the passenger side. Looking at my video, it looks like there's a small gap in the lower passenger corner that will allow you to fish them out with a magnet tool or maybe even your finger.
    Here's the type of magnet tool I'm talking about.
    https://amzn.to/32FVUSl
  2. Feb 4, 2021 at 7:16 PM
    Bluecord
    Bluecord [OP] Well-Known Member
    Jeff
    Louisiana
    2003 Tacoma 4x4 TRD Lunar Mist Metallic
    Thanks Tim! I have the flex magnet thing. I'll go fishing tomorrow night after work. What are the chances I screwed anything up dumping the bearings into the bell housing?
  3. Feb 4, 2021 at 8:17 PM
    Timmah!
    TIM
    Very doubtful anything could get messed up. The flex plate is a beefy hunk of steel and so is the torque converter. The ball bearing would get shot around in there but I doubt they'd do any real damage. It does look like your flex plate teeth got a little chewed up from the starter gear but it's not remotely bad enough to warrant replacing the flex plate in my opinion.
  4. Feb 8, 2021 at 1:50 PM
    Bluecord
    Jeff
    Louisiana
    Pulled the inspection plate and 2 bearings fell out. Backed the truck up on ramps and jacked the drivers side up. Fished around with a magnet and got nothing. Started the truck and didn't hear any bearings pinging around in there. Drove it a few hundred yards starting and stopping aggressively to try to shake things up and heard nothing, so I buttoned everything back up. Sure am hoping that was all of them! Thanks to everyone for the help and advice!
