Truck won't track straight after lift
Discussion in 'Suspension' started by gmartin284, Sep 12, 2017.
  1. Sep 12, 2017 at 9:45 AM
    gmartin284
    gmartin284 [OP] Well-Known Member
    Gage
    2008 Tacoma 4x4 double cab
    I'm currently running 5100s on my dcsb set at 2.5" and love the look but I'm not sold on the ride. I also switched to 285s after the lift so obviously the handling is going to be altered some. I've noticed though a lot of times I have a steering wheel shake and the truck itself just doesn't seem to track straight like it did previously. I'm curious if I need to swap out the stock coils for some ome or just get it re aligned and see if that helps?? Any help is appreciated!
  2. Sep 12, 2017 at 9:47 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    When does the steering wheel shake? At speed on the highway? Turning corners? Going over bumps?
  3. Sep 12, 2017 at 9:48 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Do you have the print out from your last alignment? This I can tell about the track.
  4. Sep 12, 2017 at 9:49 AM
    JDAM
    JDAM Well-Known Member
    J
    Worshington
    12 DCSB TRD OR
    most definitely get it aligned after installing a lift. Then go from there.
  5. Sep 12, 2017 at 9:49 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Swapping out coils will give you smoother ride, but may not fix your problem at hand.
  6. Sep 12, 2017 at 9:50 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Oh and, did you get an alignment after the lift installation?
  7. Sep 12, 2017 at 1:14 PM
    gmartin284
    Gage
    I had it aligned after the lift was on but not sure if it was done correctly, I don't have the alignment sheet to tell. It seems to shake most between 45-55 mph on relatively straight roads. I've read road force balancing might do the trick but that doesn't really explain why I only feel it some of the time.
  8. Sep 12, 2017 at 1:51 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I would start with a wheel balance. A weight may have been knocked off the wheel at some point, and now it's out of balance. Once that's done correctly, then let's take a look at your alignment if the issue persists. Make sure everything up front is torqued to spec to eliminate any suspected issues as well.
  9. Sep 12, 2017 at 2:08 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    wheel balance,alignment,tire pressure
  10. Sep 12, 2017 at 2:17 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    What aftermarket UCAs did you go with?
    scottalot likes this.
  11. Sep 12, 2017 at 4:32 PM
    gmartin284
    Gage
    Stock uca's
  12. Sep 12, 2017 at 4:33 PM
    gmartin284
    Gage
    I'll start there thanks man
  13. Sep 12, 2017 at 4:37 PM
    eon_blue
    Azusa, CA
    Stock UCAs with that much lift will make it hard to get properly aligned. Also, for a better ride you want the 5100s set to 0 and get the right aftermarket coils to provide the lift...stock coils with maxed out 5100s makes for a very harsh ride.
    TacoCat and Clearwater Bill like this.
  14. Sep 12, 2017 at 4:39 PM
    eon_blue
    Azusa, CA
    I'm not too familiar with 2nd gen OME coils but I think OME 887s are good for about 3" of lift
  15. Sep 12, 2017 at 5:25 PM
    geekhouse23
    There's your problem.
    scottalot and taczilla like this.
  16. Sep 13, 2017 at 7:09 AM
    gmartin284
    Gage
    how do you like the spc uca's? Also curious if getting a full ome leaf pack is worth the money or if a progressive aal will be fine. Im at 130k on the current leaf pack..
  17. Sep 13, 2017 at 7:24 AM
    geekhouse23
    A new pack would probably be the best way to go.
  18. Sep 13, 2017 at 7:25 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    geekhouse23[QUOTED] likes this.
  19. Sep 13, 2017 at 7:28 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Yup, been there, done that.
    You need new UCAs.
  20. Sep 13, 2017 at 7:55 AM
    Z7Xtreme
    Z7Xtreme Always Overestimated
    Chuck
    In a tree somewhere
    2015 trd Black Ops edition
    884's and 5100's with HS 1/4" taco lean spacer,1 inch toytec block and 5100's,SPC uca's,SCS Ray 10 wheels,265/75/16 Falken Wildpeak AT3,oem running boards,oem skid plate,WeatherTech floor liners,WeatherTech window deflectors,Access tonneau cover,WeatherTech stone and bug shield ,BPF tow hook,oem bed mat,pro grill,tacomabeast headlights,cali raised ditch brackets with Rigid lights,Rough country 30” lightbar on Rigid brackets RCI bedrack, KC rear lights,maxtrax,dual rotopax.
    You'll never get close to the 3* of caster you need with stock uca's,so going back for another alignment would just be a waste of time and money.I've also been there and done this...
