Truck won't turn in 4wd
Discussion in 'New Members' started by T@coTue5day79, Dec 16, 2020.
  1. Dec 16, 2020 at 4:31 PM
    T@coTue5day79
    T@coTue5day79 [OP] New Member
    Taco
    96 Tacoma 4cyl 2.4 4x4
    Added lockers and Ford Ranger bed lol
    Newbie here! I recently bought a 96 tacoma 2.4 4x4 with lockers added. I tried 4wl initially when I bought it but that was it. We had some bad weather today so I decided to put it in 4wh... Everything was going well until I tried to turn. The truck pretty much stopped rolling and acted like it was in a bind.... I'm talking wheels at 45 degrees.....I had to stop in the road and put it down in 2wh. What could the problem be?
    Black DOG Lila likes this.
  2. Dec 16, 2020 at 4:34 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Not supposed to use 4wd on dry hard surfaces otherwise you will bind up or worse brake something
  3. Dec 16, 2020 at 4:37 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    Two days till Friday..
    Heyyo_Friday, wilcam47, Sig45 and 2 others like this.
  4. Dec 16, 2020 at 4:38 PM
    T@coTue5day79
    Taco
    It was freezing rain and sleeting...I had some spinning that's why I decided to turn on 4wh
  5. Dec 16, 2020 at 4:41 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It’s how 4WD works. It’s not AWD. So normal.
    Black DOG Lila and asuchemist like this.
  6. Dec 16, 2020 at 4:43 PM
    2BUKU
    2BUKU Well-Known Member
    Peter
    San Diego, CA
    2014 TRD Off Road Double Cab
    King coilovers, Toyo A/T 33's yadda., yadda...
    Same thing happened to me when I bought the truck and tried to show off without having a clue. Just don't run it on dry pavement in 4lo and you'll be fine. There is a thread somewhere explaining how much stress you put on a locked system when turning.
  7. Dec 16, 2020 at 4:45 PM
    T@coTue5day79
    Taco
    See I'm used to open diff in my Jeep so this is a new animal to me...I know.....I know. Don't get the cross out just yet.
  8. Dec 16, 2020 at 4:46 PM
    T@coTue5day79
    Taco
    I was in 4 high but I guess it's either one?
  9. Dec 16, 2020 at 4:47 PM
    rnish
    Tacoma 2nd gen
    Yes
  10. Dec 16, 2020 at 4:49 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Yeah don't do that. Tight turns like in a parking lot. Not good. Welcome to TW
  11. Dec 16, 2020 at 4:52 PM
    eon_blue
    Azusa, CA
    asphalt has a lot of traction for 4wd even when wet. Making slow tight turns in 4wd on asphalt is going to bind it up. Find a dirt road to put her in 4wd on and you'll be fine
  12. Dec 16, 2020 at 4:52 PM
    T@coTue5day79
    Taco
    Yeah I had an AWD Honda CR-V and my Jeep is open diff so lockers are def new to me
  13. Dec 16, 2020 at 4:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    That’s Normal.
    You really don’t what to run 4WD on high traction surfaces. The situation is worse if turning.
    Locked and turning on a dry nonslip surface can be bad. Real bad.
    And before some one says you CAN use 4WD on pavement, YES you can.
    But the circumstances are NOT NORMAL under which you do this.
  14. Dec 16, 2020 at 4:53 PM
    eon_blue
    Azusa, CA
    Your Tacoma has open diffs too
  15. Dec 16, 2020 at 4:53 PM
    eon_blue
    Azusa, CA
    Manual locking hubs are not the same thing as differential lockers
    elduder and T@coTue5day79[OP] like this.
  16. Dec 16, 2020 at 4:54 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    Your tacoma has open diffs too. It operates functionally the same as your jeep in 2wd and 4wd.
    Are you confusing hubs with lockers?
  17. Dec 16, 2020 at 4:55 PM
    T@coTue5day79
    Taco
    Ok well I have locking hubs
  18. Dec 16, 2020 at 4:56 PM
    eon_blue
    Azusa, CA
    Your Jeep has a solid front axle, Tacoma is independent front suspension (IFS) which uses CV axles to turn the front wheels when the hubs are locked and 4wd is engaged. CV axles do not like to bind up, they tend to go snap if it's too severe
  19. Dec 16, 2020 at 4:58 PM
    T@coTue5day79
    Taco
    I appreciate the input guys and gals. I'm learning I'm never too old a dog to learn something new.
    Black DOG Lila, lynyrd3 and kairo like this.
  20. Dec 16, 2020 at 4:58 PM
    eon_blue
    Azusa, CA
    It's a common misunderstanding, no worries. Differential lockers are a whole other topic on their own lol
