Truck won't turn in 4wd
Discussion in 'New Members' started by T@coTue5day79, Dec 16, 2020.
  1. Dec 16, 2020 at 4:58 PM
    T@coTue5day79
    T@coTue5day79 [OP] New Member
    Taco
    96 Tacoma 4cyl 2.4 4x4
    Added lockers and Ford Ranger bed lol
    I backed off when I felt resistance so I think I'm good on that front
    Black DOG Lila likes this.
  2. Dec 16, 2020 at 5:01 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    If you really want to monkey around with it, disconnect your rear driveshaft and put the front end up on jack stands while it's in 4wd. If you spin one tire hard, it should spin independently of the other tire. If you spin slow they might still spin together. You can turn the wheel and mess around with this and see if anything happens to be binding in a weird way
  3. Dec 16, 2020 at 5:01 PM
    eon_blue
    Azusa, CA
    I'm sure you are, it happens all the time. I've experienced binding before even on offroad trails, especially in places with a lot of traction like Moab. Just have to know when to stop/when not to push it.
    I did blow a CV axle once turning off a snowy street into a covered gas station, hit the dry part of the concrete and heard a snap. Drove down the road to the sound of a floppy CV axle wompwompwompwompwomp
    Point being, you'll know if you broke something lol
  4. Dec 16, 2020 at 5:01 PM
    T@coTue5day79
    Taco
    Nah...I think I'll just wait for the next snow. Jeep will be sad but will get over it
  5. Dec 16, 2020 at 5:02 PM
    lynyrd3
    Bill
    East Central Upstate NY
    Welcome to TW :hattip:
  6. Dec 16, 2020 at 5:05 PM
    T@coTue5day79
    Taco
    Soooo.... What is the point of manual locking hubs? I'm getting edumacated
  7. Dec 16, 2020 at 5:06 PM
    kairo
    kairo >_>
    Nor Nev
    Locking hubs, also known as free wheeling hubs are fitted to some (mainly older) four-wheel drive vehicles, allowing the front wheels to rotate freely when disconnected (unlocked) from the front axle. This is done to reduce the mechanical resistance of the front-portion of the drivetrain when four-wheel drive is not in use.[1] The hub, along with the wheel, is designed to engage (lock) onto the axle, to be powered by the drivetrain in four-wheel drive; or the hub can disengage (unlock) from the axle when four-wheel drive is not needed, thus allowing the front wheels to rotate freely within the hub. The hub is a component where the wheel is directly mounted to, and is outside the axle.
    It's just an older way of doing 4wd systems. Modern vehicle all lock their hubs automatically
    Black DOG Lila and TnShooter like this.
  8. Dec 16, 2020 at 5:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    In short:
    They allow the hub and axle to “unlock”.
    That way you aren’t turning the front axles in 2WD.
    kairo likes this.
  9. Dec 16, 2020 at 5:09 PM
    T@coTue5day79
    Taco
    I ask because they have been in lock position ever since I bought the truck. Should I unlock them? This truck has been....tweaked so I'm afraid to do much lol
  10. Dec 16, 2020 at 5:10 PM
    kairo
    kairo >_>
    Nor Nev
    Yah, no reason to have them locked unless you are currently using the 4wd system. Just puts added wear and tear on the axles
  11. Dec 16, 2020 at 5:13 PM
    TnShooter
    Deogee
    STOCK
    I think the old saying goes -
    There are 2 type of people that have Locking Hubs.
    Those that have “forgot” to lock them, and those that will....
    Yes, OP. Unlock them when you are in 2WD.
  12. Dec 16, 2020 at 5:18 PM
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    Although I know people who have done or did it fairly regularly, stay under 45 in 4hi and if I remember under 55 when hubs locked and in 2wd.
    4hi and over 45 and you may lose traction unless it’s been upgraded.
    If there was just very minor slipping, you probably didn’t need 4wd.
    T@coTue5day79[OP] likes this.
  13. Dec 16, 2020 at 5:29 PM
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Just be glad your CV's are weaker then your transfer case. The bind occurs in the t-case not the diff. Then it locks up from the unequal rotation of the front and rear tires. If your lucky you blow a CV. If your unlucky you blow the input gear in the t-case. CV's are a hell of a lot easier to replace. lol
    eon_blue[QUOTED] likes this.
  14. Dec 16, 2020 at 5:31 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
  15. Dec 16, 2020 at 6:39 PM
    #35
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Also you don’t have the 2.4L in your truck. You have the bigger 2.7L 3RZ engine. The 2.4L only came in the base model 2WD.
  16. Dec 16, 2020 at 7:08 PM
    #36
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
  17. Dec 16, 2020 at 7:31 PM
    #37
    kairo
    kairo >_>
    Nor Nev
    This is why everyone's first upgrade should be an atlas T/C.
    Actually I don't even know if atlas makes t/c's for the tacomas. Do they?
  18. Dec 16, 2020 at 7:32 PM
    #38
    gunn_runner
    gunn_runner www.gunnphotoservices.com
    Rocky River, OH
    2013 DCLB TRD
    OME 886 & Dakars. 35" Mickey Thompson Baja Boss
    Be nice. We all started somewhere
  19. Dec 16, 2020 at 7:36 PM
    #39
    theesotericone
    Bishop CA
    They do. I almost went with an Atlas 4 instead of dual cases when I built my rig. The problem is it's a shit ton more work to get the Atlas to fit. It was only about 1K more to get the Atlas but the extra strength and work isn't really needed for the 3.4L whopping 190HP. lol
    kairo[QUOTED] likes this.
  20. Dec 16, 2020 at 7:39 PM
    #40
    kairo
    kairo >_>
    Nor Nev
    I'm getting out of the loop. I remember that the early taco guys were always running doublers, and us jeep guys ran clocked D300s with 4:1 gears or atlas t/c's
