Truck won't turn over after trying to install mod
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fistingfury, Feb 3, 2019.
  1. Feb 3, 2019 at 6:05 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    I would double check the fuses. And if you can borrow a multimeter that will definitely help with the troubleshooting.
  2. Feb 3, 2019 at 6:12 PM
    fistingfury
    fistingfury [OP] Well-Known Member
    Fayetteville, NC
    2016 Blue Tacoma TRD OR
    Thanks y’all. The unit has been uninstalled and all wiring has been back to stock settings and it hasn’t started. I checked all connections to ensure proper fitment and all fuses seem to be fine and working. Might have to just toss it up as a loss and get it to to a dealership :annoyed:
  3. Feb 3, 2019 at 6:21 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Do you have a wiring diagram of what you were doing here we could see ?
    Do you have a meter ?
  4. Feb 3, 2019 at 6:28 PM
    fistingfury
    Fayetteville, NC
    No meter unfortunately.
    I was installing this. Only two plugs moved and the unit had a loose wire that went into the starter.
    https://youtu.be/bnHpZbxaJVs
  5. Feb 3, 2019 at 6:31 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Have you tried this?
    Trouble_The_Tacoma and texbaz like this.
  6. Feb 3, 2019 at 6:32 PM
    2016Tacoman
    J
    Did you have the truck battery unplugged when doing this ?
    To start I would go back and look at the pins in the plugs and make sure they did not recess/ get pushed back (or damaged/bent) in the plug (keeper damaged). Especially the plug up against the firewall. Those up there are tiny and fragile imo.
    That's my bet, a screwed up pin.
  7. Feb 3, 2019 at 6:34 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Better get that wallet ready.
  8. Feb 3, 2019 at 6:37 PM
    texbaz
    texbaz Well-Known Member
    "Buffalo Creek" TX
    2018 Tacoma Silver Sky Metalic 4WD DCSB TRD OR
    What fuse positions were you adding too? I have a schematic that calls out what the fuses do. I would check the fuses you were removing and installing with a multi meter do a continuity check.
  9. Feb 3, 2019 at 6:40 PM
    2016Tacoman
    J
    Watch the video, its just plug and play / hopefully.
    fistingfury[OP] likes this.
  10. Feb 3, 2019 at 6:45 PM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    A multimeter is essential to troubleshoot a problem like this.
    Gunshot-6A likes this.
  11. Feb 3, 2019 at 6:47 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I bet you bent a pin on one of the connections. Pull them and inspect.
  12. Feb 3, 2019 at 6:52 PM
    texbaz
    "Buffalo Creek" TX
    did you try your spare key fob
    Trouble_The_Tacoma likes this.
  13. Feb 3, 2019 at 6:55 PM
    texbaz
    "Buffalo Creek" TX
    really a pretty straight forward install. definitely check for pushed pin or bent. also really need to ring out the fuses those Low profile mini's can be tough some times.
  14. Feb 3, 2019 at 6:56 PM
    Markcal
    Markcal Well-Known Member
    X2...The connectors you were inserting were "male", so there is a good chance one or more of the fine "female" pin may be damaged or recessed. I would start there and if you have an eye loupe, it would help in the inspection of the pins by magnifying them.
  15. Feb 3, 2019 at 7:02 PM
    #35
    VaToy
    Parts Unknown
    Look at the wiring harness closely. That is your problem.
  16. Feb 3, 2019 at 7:05 PM
    #36
    Herniator
    Edmonton
    When you were installing the remote start. You may have accidentally unplugged another harness.
    Gunshot-6A and fistingfury[OP] like this.
  17. Feb 3, 2019 at 7:08 PM
    #37
    fistingfury
    Fayetteville, NC
    Thanks for the suggestions y’all. I’m trying everything I can. I really appreciate them all.
  18. Feb 3, 2019 at 7:14 PM
    #38
    texbaz
    "Buffalo Creek" TX
    can you use your key fob to operate the locks?
  19. Feb 3, 2019 at 7:46 PM
    #39
    fistingfury
    Fayetteville, NC
    Yes. Key fobs are working. Tried both of them, still no luck.
  20. Feb 3, 2019 at 8:12 PM
    #40
    texbaz
    "Buffalo Creek" TX
    So when you walk up tp the vehicle touch the handle the Fob is locking and unlocking. then did you look at the fuses under the hood?
