Truck won't turn over
Discussion in '3rd Gen. Tacomas (2016-2023)' started by enjm10, Mar 29, 2020.
  1. Mar 29, 2020 at 10:23 PM
    enjm10
    enjm10 [OP] Well-Known Member
    Eric
    NM
    2020 White Double Cab
    5% Front strip and doors, 20% wrapped around the rest of the truck.
    I have a 2020 double cab SR, ive owned it since the beginning of the year. Every so often (4 times now) since purchase I can get in the truck and turn the key to start it and it wont actually start up. I turn the key back off and try again and it wont start it wants to give but it wont start. I dont want to drain the battery or kill the starter but the only way to get it to run is to pump the gas pedal and let it sit for awhile before trying to start it again.
    Anyone else have this problem with a new truck? I finally tightened my battery connections, I installed fogs today, and tightened them on good and the truck started right up. I do not know for sure what could be causing it. Just wondering if anyone else has had this problem. I'm gonna monitor it, it eventually starts but it seems like it's happening every 3-4 weeks
  2. Mar 29, 2020 at 10:28 PM
    tcjacado
    tcjacado Well-Known Member
    Maybe the fuel pump... there is a recall on earlier models.
    enjm10[OP], FishnTx and GillyLink like this.
  3. Mar 29, 2020 at 11:13 PM
    Salvo
    Salvo Member
    Louisiana
    2018 TRD OR DCSB 4wd
    Monitor it? I’d have the dealer address that ASAP.
  4. Mar 29, 2020 at 11:19 PM
    NMTrailRider
    NMTrailRider Well-Known Member
    New Mexico
    Bad battery (or alternator)? Just because a battery is new doesn’t mean it isn’t a bad one. It happens. Have someone test the battery.
    whatstcp and enjm10[OP] like this.
  5. Mar 29, 2020 at 11:22 PM
    NMTrailRider
    New Mexico
    I doubt your “pumping the pedal” and letting it sit is doing much of anything. Correlation isn’t always causation. Sure sounds like a faulty battery to me.
  6. Mar 30, 2020 at 9:40 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    yea, pumping the pedal does nothing.
    9TRDTCO and enjm10[OP] like this.
  7. Mar 30, 2020 at 10:40 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    On a new truck that doesn’t crank over, i’d re-check the battery connections and cleanliness before anything else......
    enjm10[OP] likes this.
  8. Mar 30, 2020 at 10:42 AM
    Shellshock
    Iowa
    ^im guessing this or the battery is shot
  9. Mar 30, 2020 at 11:39 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    As has been said. New batteries can be bad.
    Brand new truck, Dealer!!!!
    G.
    Big tall dave and enjm10[OP] like this.
  10. Mar 30, 2020 at 12:29 PM
    enjm10
    Eric
    NM
    When I installed my fogs the negative connection wasnt as tight as I wouldve liked it. But after installing fogs I did tighten it down pretty good. I will be making a trip to the dealer at some point to have it checked out. I appreciate everyone's advice and will look into it and post back with what the dealership or I can come up with
    Big tall dave likes this.
  11. Mar 30, 2020 at 1:49 PM
    mhornco
    mhornco Well-Known Member
    Likely it was loose then, based on your previous post where truck seems fine now. A loose connection can be a pain as sometimes you get good contact, sometime you don't
  12. Mar 30, 2020 at 1:52 PM
    Dano461
    Dano461 Well-Known Member
    2002 Reg Cab PreRunner
    Needs a new carburetor
    Superdave1.0 likes this.
  13. Mar 30, 2020 at 3:29 PM
    Dano461
    Might be Points & Condenser as well
  14. Mar 30, 2020 at 3:31 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
  15. Mar 30, 2020 at 3:43 PM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    Yeah, pumping only did something with carbonated systems where when you pressed the gas pedal it squirted extra raw gas. This helped with when you needed to accelerate. Fuel injection systems don't put extra fuel in the system by pumping. So I'm pretty sure that's just coincidental. It's a new truck, don't fret just take it in and have them make it right.
    NMTrailRider[QUOTED] likes this.
