Truck wouldn't start. Starter rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Nov 26, 2017.
  1. Dec 14, 2017 at 7:59 AM
    #61
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Umm......What???when people jump each other, one usually has a battery below or near 12 volts, and usually the good truck is running and pumping out a solid 13.5 v. Add on top of that you have double the amps, which is basically how much 12v you can push along the wire at one time. 1 volt with 300 amps will kill a human. 300 volts with .2 mA will tickle and nothing more.
  2. Dec 14, 2017 at 8:00 AM
    #62
    Nomad_Pilot
    Clay
    Ft Collins
    Oh greatest charge sorry yes you are correct
  3. Dec 14, 2017 at 8:00 AM
    #63
    richiep
    richiep Well-Known Member
    Rich
    NY
    2006 Tacoma Access 4WD SR5
    Trd s/c 2.85 pully Walbro 255 f/p Urd stage 3 clutch Hurst core shifter Afe cai
    no worries
  4. Dec 14, 2017 at 8:03 AM
    #64
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Yes
  5. Dec 14, 2017 at 8:04 AM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Didn't rule out mine.
    Thyces[OP] likes this.
  6. Dec 14, 2017 at 8:05 AM
    #66
    Thyces
    Ontario
    2009 DCLB TRD Sport
    PA speaker?
  7. Dec 14, 2017 at 8:07 AM
    #67
    richiep
    Rich
    NY
    The part where you were able to start the truck without a jump & something or a "culprit" is draining the battery!
    If you have a fully charged battery does the truck start?
    Without a jump?
  8. Dec 14, 2017 at 8:15 AM
    #68
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Installed a brand new battery and it wouldn't start.
  9. Dec 14, 2017 at 8:17 AM
    #69
    richiep
    Rich
    NY
    just double check the voltage & current state of the new batt & if thats in spec, then you have no choice but to pull & test the starter
  10. Dec 14, 2017 at 8:23 AM
    #70
    Pigpen
    Dan
    Northwest Montana
    This is a real ball buster if it was just the starter the whole time. Fahk
  11. Dec 14, 2017 at 8:26 AM
    #71
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I'm rebuilding the starter tomorrow regardless.
  12. Dec 14, 2017 at 8:27 AM
    #72
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Fuckit. Now I have knowledge I didn't and a secondary battery for a dual setup.
  13. Dec 14, 2017 at 9:01 AM
    #73
    Nomad_Pilot
    Clay
    Ft Collins
    I like your attitude
    I married my tacoma likes this.
  14. Dec 14, 2017 at 9:17 AM
    #74
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Life's too short to bitch
  15. Dec 14, 2017 at 9:19 AM
    #75
    Pigpen
    Dan
    Northwest Montana
    Amen brother
  16. Dec 15, 2017 at 4:54 AM
    #76
    Thyces
    Ontario
    2009 DCLB TRD Sport
    So..... Life lesson learned......always double tap. I tapped the shit out of the starter and she turned over, no problem. A little hesitation, but no problem. I'll have my rebuild kit later today. Now I have another question. What can I replace the drainage "plug" with so it is closed off from anything getting in but still able to drain? (I broke it trying to remove it)
    dziner likes this.
  17. Dec 15, 2017 at 7:17 AM
    #77
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    Duct Tape.:anonymous:
    (Thanks for the updates :thumbsup:)
    Torspd and Thyces[QUOTED][OP] like this.
  18. Dec 15, 2017 at 10:53 AM
    #78
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    While your digging around working on starter R+R , might be worth your time to follow the negative wire from the battery terminal out , remove and clean any connections and replace. Give the battery to engine wire special attention .
    When you jumped your truck, did you put the negative jumper clamp on the battery or ground it on engine metal?
  19. Dec 15, 2017 at 11:04 AM
    #79
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I've replaced all wires from and to battery with ofc high strand 0 gauge cable with soldered connectors (big 4 upgrade). I will be detaching, cleaning and tightening up all connections just to be sure. I never ground to body. I have just 2 connections on body, main and inverter in cab. I have a negative buss bar for all the toys.
  20. Dec 15, 2017 at 1:47 PM
    #80
    Tacosail
    Jerry
    '13 white ACLB
    When it wouldn't start, did you put the negative jumper clamp on the battery or on some metal part on the engine?
