Truck wouldn't start. Starter rebuild
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thyces, Nov 26, 2017.
  1. Dec 15, 2017 at 2:03 PM
    #81
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    On the battery.
  2. Dec 15, 2017 at 6:18 PM
    #82
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Yep, tapping on it works most of the time. My starter solenoid was also the sorce of my drain on my battery. As far as a rubber piece, I just put a long hose on mine and tucked it into the frame so water would stay out of it on deep crossings. Never had a problem.
    Thyces[OP] likes this.
  3. Dec 16, 2017 at 7:38 AM
    #83
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    when it wont start, you might try putting the negitive cable on the battery ,and the other end on the metal on the motor to confirm you have a good ground connection to the motor.
  4. Dec 16, 2017 at 7:40 AM
    #84
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Hmm... That's a good idea. Ever since I tapped the starter it's started right up. Next time I'll try that though.
  5. Dec 16, 2017 at 9:55 AM
    #85
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did you pull the starter yet?
  6. Dec 16, 2017 at 9:58 AM
    #86
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  7. Dec 16, 2017 at 10:37 AM
    #87
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Not yet. Working too much lately. I'm hoping to get to it tonight. Thanks for the link.
    Torspd[QUOTED] likes this.
  8. Dec 18, 2017 at 10:43 AM
    #88
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  9. Dec 18, 2017 at 10:47 AM
    #89
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Finished work yesterday at 7 pm. Probably doing the same today.... Holiday bills....
    PzTank[QUOTED] likes this.
  10. Dec 19, 2017 at 6:48 AM
    #90
    PzTank
    Above the Notches
    Sounds like you’re working too hard :militarypress:...Merry Christmas!
    Looking forward to seeing how this works out for you (the truck stuff, not Christmas..)
  11. Feb 12, 2018 at 2:25 PM
    #91
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
    This is exactly what I want to do for my setup. I have a single 31M battery and just ordered a Engel MT45. I was wondering how it looks. Would you please share pictures of your setup? Thanks in advance
    dziner[QUOTED] likes this.
  12. Feb 17, 2018 at 3:27 PM
    #92
    dziner
    dziner Well-Known Member
    Jonathan
    Harrisburg, Pennsylvania
    2014 Toyota Tacoma TRD Off-Road
    Bilstein 5100 (front) | OME 885 springs | Bilstein 5160 (rear) | OME Dakar medium leafpack | JBA UCA | Cooper S/T Maxx 265/75 R16 | ARE Z-Series topper | Renogy 100W solar panel | SnoMaster TR42 fridge | sleeping platform | Mobtown sliders | Custom Car Grills grill insert
    Here's a video I did a few weeks ago that covers the sleeping platform and a bit of the solar setup. I didn't have the fridge mounted at the time, I was sick as hell, and it was cold as hell, but I created a video. I should probably do a better version at some point.
    17taco4x4[QUOTED] likes this.
  13. Feb 17, 2018 at 3:36 PM
    #93
    17taco4x4
    17taco4x4 FZJ80
    Orlando
    Porter, TX
    1997 Land Cruiser
    Thanks man for the video it’s very helpful
  14. Feb 17, 2018 at 4:17 PM
    #94
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Update: I ended up making all new 1/0 wiring with marine grade tinned connectors including alternator into stock fuse box, replacing my original group 31 deep cycle agm with a group 27 agm, just to have to rebuilt the starter to actually fix the issue.
    PzTank likes this.
  15. Feb 19, 2018 at 4:17 AM
    #95
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    At least your wires are upgraded for future current loads.
    Did you purchase one of those starter rebuild kits with the contacts, and that is what fixed the problem?
  16. Feb 19, 2018 at 4:43 AM
    #96
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Yep. $35 us For the two contacts and the plunger. I already had upgraded wiring. I cut off the ends and recrimped new tinned connectors wrapped with rubber tape. My original connectors I felt had too big of a hole. I was looking to eliminate the possibility of any faulty connections.
  17. Feb 19, 2018 at 6:20 AM
    #97
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Sweet. Glad that you came through with the solution. :thumbsup: I'll take that as a win too. ;) :humble:
  18. Feb 19, 2018 at 6:44 AM
    #98
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Thanks again for all the info. You've chimed in on a few of my posts always with good advice.
  19. Feb 19, 2018 at 7:16 AM
    #99
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pure luck. Swears. Lol. You're welcome. Glad to help.
  20. Feb 19, 2018 at 7:24 AM
    #100
    RedEmpire
    RedEmpire Well-Known Member
    Southern Pines, NC
    2017 MGM Tacoma DCLB 4X4
    I saw it was your starter, just wanted to note for others that may have the same problem that the cabling can often be the culprit. I replaced everything and still couldn't figure out what the problem was. I finally pulled all the cables and the positive side was corroded for half of it's length. It was very strange because the ends looked fresh on a visual inspection. Once I cut into the cable, it looked like corrosion city.
    llamasmurf likes this.
