Truck wouldn't start. What could be the issue?
Discussion in 'Technical Chat' started by 907Yoda, Jul 13, 2014.
  1. Jul 13, 2014 at 5:30 PM
    907Yoda
    907Yoda [OP] currently trying to get lost...
    Rapid City SD
    2015 TRD Off Road
    13% Tinted, 5000k HID headlights and fogs, Wet Okole Seat Covers, Weathertech wind deflectors, 13" Shorty antenna, PowerAid throttle body spacer, XTP Intake Manafold Spacer, Magnaflow cat back exhaust, grillcraft grill
    Hey so I was so confused last night. I met up with someone last night and it was so hot that I left my truck running for the a/c ideling while we talked in it for 45ish minutes. I turned it off and we went to go grab a bite to eat then when I came back to start it to leave it wouldnt start. kept turning over just wouldnt fire up. I left and got a ride back to it about 2 hours later and it fired right up like nothing ever happened. What could have caused this issue? It has about 8400 miles on it, still under warrenty. Should I bring it to the dealer to get it checked out?
  2. Jul 16, 2014 at 5:04 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    If it were me and my 1 year old truck did that I would definitely take advantage of the warranty and have it checked out or at least call to ask why that would happened.
    If you do call the dealership try and talk to a Master Tech instead of some sales rep or floor manager who will probably just give some BS answer and blame it on the truck idling for 45 minutes.
  3. Jul 16, 2014 at 7:15 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    Thanks. Sounds good I havent had a problem since this instance so i didnt know if it was just chance or something. But i will call tomorrow and post what i find out
  4. Jul 16, 2014 at 7:23 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    never heard this before...
    did you try removing the key a couple times?
    maybe the trucks immobilizer didnt read the key...causing it just to turn over.
    if it does it again, see if the small car with key in the middle (right of the clock under the radio) is blinking while the key is in the "on" position...if it is, then its not reading the key, if its off then youre good on that
  5. Jul 16, 2014 at 8:31 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    Yes I did remove the key a few times. Tried for a 5ish minutes with second breaks in between then gave up. Everything turned on except the motor. If it dosent reconize the key will the radio come on and truck still turn over? For a while I thought it was something with my fuel pump. I did not think to look at the car key light that might have been the issue. If the problem no longer exists Toyota wont be able to find the problem but the mechanics may have a few theories.
  6. Jul 16, 2014 at 8:46 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    if key not recognize yes it will still turn everything one and turn over but wont let the ecu fully turn the engine on...
    reason i know was cuz a couple years back my receiver some how got shorted and it would do everything but fully turn over the engine...had to tow it to toyota...
    but since you got it to run again, im guessing it my not be the case...
  7. Jul 16, 2014 at 8:59 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    WeatherTechs, Console Vault, OEM Bed Mat, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, Exterior Cargo Net, OEM Toyota Cargo Divider, Cobra CDR 840 Dash Cam, Sliding Rear Window Security Bar, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Full Debadge except TRD OEM Red Tailgate Badge, Undercover SE Tonneau
    Definitely go to dealer if for nothing else to document the issue.
  8. Jul 16, 2014 at 9:05 PM
    sean266
    sean266 #ThinBlueLine Moderator
    The dealer will prob say they can't help u if they can't duplicate the problem...but it's worth a try, and way to document said issue.
  9. Jul 24, 2014 at 6:33 AM
    SSN
    SSN New Member
    steve
    Ky
    tacoma
    2005 tacoma will not turn over no guages work dome light works battery is good acts likes no power is coming to key switch is there a relay or fuse for this thanks SSN
  10. Jul 24, 2014 at 9:46 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, 31" tires, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera, CB
    In the old carburetor days, heat-related starting problems were caused by 'vapor-lock'. Fuel would vaporize in the fuel lines that were close to the exhaust.
    Cooling down was the only solution. Then it would fire up as if nothing were wrong. Idling on a hot day with A/C on for 45 minutes would maximize the heat generated under the hood.
    Its not supposed to happen with EFI, but it sure seems like it did.
  11. Aug 4, 2014 at 7:12 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    I talked with toyota a week or so ago they were convinced it was a one time issue nothing to worry about.
    So then same problem occured again yesterday. I drove it right in there next time it started and dropped it off with them. Couple hours later they called me and said after some tests they have come to the conclusion that my main computer has a glitch in it. (Possibly a bad solder connection) One of many timers in the truck computer will not start for system diagnostics. After some great details I caught myself just nodding my head cause they lost me. But they have never seen any problem like it so they ordered a whole new computer system for the truck just to be safe...
  12. Aug 4, 2014 at 7:57 PM
    sean266
    At least they seem to have found a solution!
  13. Aug 4, 2014 at 8:41 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Lynnwood, WA
    Tacoma 4x4
    Snugtop cab high canopy.
    Vapor lock can't occur with the fuel pump in the tank. In the carburetor days the fuel pump was often on the engine driven mechanically. If the gas in the line to the tank vaporized the pump couldn't pull any fuel from the tank. The pump in the tank can push any vapor between it and the engine with no problem.
  14. Aug 4, 2014 at 8:50 PM
    csayno
    csayno Well-Known Member
    Maui, Hawaii
    13' DCSB PreRunner SR5
    Nerf bars, Weather Tech floor mats, AVS Bug Deflector, 265/75/26 Duratrac Wranglers.
    Wow. Good news depending how you look at it. lol. How long will it take till you get the truck back?
  15. Aug 4, 2014 at 10:29 PM
    907Yoda
    Rapid City SD
    2015 TRD Off Road
    Parts are on order and have my appointment Thursday. They said approx 4-5 hours to do everything
