Trucks “wondering” all over the road
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cmuelrath, Dec 28, 2024.
  1. Dec 28, 2024 at 5:52 PM
    Cmuelrath
    Cmuelrath [OP] Active Member
    Colton
    2001 Tacoma 2.7
    I have a 2001 Tacoma 2.7. When driving down the road/hwy it wanders all over the place. Feels like the front end is loose underneath. When I on jacks and wiggle wheels up down/side to side everything is tight. I recently just did icon 2.5 in front and ome rear leaf springs. New steering rack. Whole front end is new withing 5,000 miles including new lower control arms/ bushings and ball joints and tie rods. The truck was fine after doing suspension drove it a couple hundred miles no problem then I did the steering rack and started having this issue. I got an alignment and now it’s even worse. When I take a turn it feels as if the front wheels catch and damn near want to throw me off the road also throws me all over the road on certain bumps. I’m taking it to a local off road shop to get a second opinion and double check the alignment. I also rotated my tires to see if that changed anything and didn’t change. TIA
    edit: once you take a turn it’s fine until you go back straight then back to the same thing. Almost like it wants to go to one direction or the other. Alignment looks good to the eye and on paper but wondering if they’re toed in too much?
  2. Dec 28, 2024 at 6:02 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It's wandering, not wondering.
    This might be a stretch, but I had some issues with the rear factory shock being too short after a small lift. It did some similar funky things until I figured out the problem. My issues were only when the rear of the truck encountered speed bumps or similar things in the road. It sounds like your issue is in the front end.
    YOTA 4X4, PennSilverTaco and 23MGM like this.
  3. Dec 28, 2024 at 6:24 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Almost sounds like a wheel bearing(s)
  4. Dec 28, 2024 at 6:53 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    it happens when the front end hit a bump or turn. I also added new icon rear shocks
  5. Dec 28, 2024 at 6:55 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    The only reason I don’t think it is is because it happens either way you turn and you don’t feel any play or bad noises when wiggling or prying Wind lifted in air
  6. Dec 28, 2024 at 6:57 PM
    O'Silver_Taco
    MD
    With pressed in bearings its hard to tell unless it under load....
    wiggle test isn't the gold standard
    Kleenax likes this.
  7. Dec 28, 2024 at 7:15 PM
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    You should ideally have at least 3.0 degrees of caster with the lift height you have. Less than that, and the steering can get sensitive at higher speeds. Going as low as 2.5 will still be manageable though. If you are using stock UCAs, and the caster is down around 1.0 degrees, that could explain the shopping cart steering you are experiencing.
    YOTA 4X4 likes this.
  8. Dec 28, 2024 at 7:21 PM
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Madjik_Man likes this.
  9. Dec 28, 2024 at 7:34 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    I have some Ksp upper control arms. They’re not adjustable but the angle is made for 2-4” of lift. When I did my suspension the truck drove great other than a little play from the bad steering rack. When I put the new steering rack in is when my problems got really bad
  10. Dec 28, 2024 at 7:35 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    That makes sense and it’s down around 1 degree. The off-road shop is going to set my caster higher this next week when I bring it in for another alignment
  11. Dec 28, 2024 at 8:00 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    You said it was fine until you put the rack in……be sure to mention that to the next shop. Hopefully it will save them some time, and you some money.
  12. Dec 28, 2024 at 8:04 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    They won't get much more than 1° out of the stock UCAs. Unless I missed somewhere you said you have aftermarket UCAs
  13. Dec 28, 2024 at 8:36 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    I do all my own work but I’m stumped so bringing it there for another alignment and possibly a diagnostic if that doesn’t fix it. I’m tempted to warranty the rack and put another one in incase it happened to be a bad rack
  14. Dec 28, 2024 at 8:37 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    I have aftermarket upper control arms with the right degree from 2-4” lift. They’re just non adjustable. Their ksp
    Red_03Taco[QUOTED] likes this.
  15. Dec 29, 2024 at 5:19 AM
    pinem56
    NE
    2018 TRDOR DCSB AT
    Get the alignment numbers/printout from the shop and verify they are doing the alignment correctly. That needs to be done to rule out the most simple explanation for your problem. There are a lot of idiots doing alignments out there, blindly following prompts on a computer screen.
    Wulf likes this.
  16. Dec 29, 2024 at 12:07 PM
    Cmuelrath
    Colton
    2001 Tacoma 2.7
    I have the printout ill post it ina bit
  17. Dec 29, 2024 at 1:18 PM
    Kaptain Random
    Kaptain Random New Member
    2004 Tacoma Access v6 4x4 ATM
    I had this problem.
    I was pursuing rack replacement.
    Found a shop willing to adjust steering shaft rack connection.
    After inspection, suggested steering intermediate shaft.
    Replaced 'steering intermediate shaft'.
    Fixed. No more wandering.
    It seems there is a 'joint' in the steering shaft designed to collapse in a collision to lessen steering wheel into chest of driver. Over years this steering intermediate shaft wears and gets 'play'. Some folks just weld it solid. Welding fixes play but removes collision safety function.
    I have a new favorite taco mechanic.
    Here is link to this sites discussion on the issue and the weld fix
    JustADriver likes this.
  18. Dec 29, 2024 at 1:23 PM
    MGMDesertTaco
    Not all Tacoma's who wander are lost. :rimshot:
    mlcc likes this.
  19. Dec 29, 2024 at 1:38 PM
    Red_03Taco
    Jerad
    I did the tac weld fix on mine, but just applied two small tac welds 180° apart from each other. I doubt those 2 small welds will prevent the shaft from collapsing. It did make a huge difference in the steering feel though
  20. Dec 29, 2024 at 2:41 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    It could be wondering. Wondering if it’ll end up in a ditch, wondering if it needs new tires
    mike759 and MGMDesertTaco like this.
