True 3" Coilovers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NTXC8D, Feb 11, 2023.
  1. Feb 11, 2023 at 9:18 AM
    NTXC8D
    NTXC8D [OP] New Member
    Jake
    Dinwiddie, VA
    2023 Black Tacoma TRD Sport DBC SB MT
    Hey Dudes,
    Looking at lifting my 23' Tacoma with 3/2 suspension lift. Would like to go 3" inches in the front, but I'm having trouble finding a coilover that actually lifts a true 3" . Icon goes to 2.75 and Toytec only lists a range of 0-3.5 , but that also has the 2nd gen grouped into that fitment which we know lifts higher than 3rd gen w same lift.
    So, with Icon listing 2.75" does that mean 2.75" is the max because that's the limit for stock front end? Ive being looking for quite a while and I have yet to find a manufacturer listing a straight up 3" front lift coilover. And if that's the max then that's fine, just wanted to make sure I'm not missing something. I'm just trying to make sure I have max clearance for 285's.
    I think i read that 1/4" tophat will give you 1/2" additional lift too right?
    Thanks in advance!
    -Jake
  2. Feb 11, 2023 at 1:09 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Fyi, anything over 2.5 starts creating a lot of problems on these trucks 100's, if not 1000's of post on that subject. Advise stay close to 2" in front.
    NTXC8D[OP] and ZColorado like this.
  3. Feb 11, 2023 at 1:18 PM
    Bishop84
    Bishop84 Well-Known Member
    Lift doesn't tire create clearance with Tacoma, if anything it usually results in the wheel rubbing worse due to lack of adjustments unless you have upgraded UCA.
    3" is too much, it will severely limit down travel and rides rough. Read up and you'll see 2.5" max, as said. 2" ideal.
    Especially on rough terrain, you want down travel, not lift.
    285's usually need upper control arms, slight inner fender movement, alignment, then lastly cab mount chop when it rubs on hard lock and compression.
    AllTacosFloat and ZColorado like this.
  4. Feb 11, 2023 at 1:22 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    You don't want 3"
    You may want big tires - Trimming
    You may want suspension travel - long travel
  5. Feb 11, 2023 at 1:27 PM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    Please don't use the shocks as the primary lifting component. Your ride will be terrible. Just had a buddy who took his truck to an install shop because his ride was so harsh. I told him to take the pre load out. Called me yesterday and said it was a completely different truck. It's better to get lift through a lift spindle. It keeps all of the geometry the same.
  6. Feb 11, 2023 at 1:30 PM
    ZColorado
    13 DCSB OR 6MT
    That's an unusual opinion...
    08BajaBoy[QUOTED] likes this.
  7. Feb 11, 2023 at 1:31 PM
    08BajaBoy
    Brian
    Southern Cal
    Yah, probably not a popular one. But I'm not sure why. It's the most logical to me.
  8. Feb 11, 2023 at 1:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    You have a prerunner. IE 2wd
    9th likes this.
  9. Feb 11, 2023 at 1:51 PM
    Bishop84
    Spindle lifts are better, just not applicable to 4x4 models unless you go drop bracket.
    08BajaBoy and ZColorado like this.
  10. Feb 11, 2023 at 2:07 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    These guys can say what they want I did the rough country 3/2 with drop bracket for the differential"original needle bearing" that's for the haters . Then I upgraded to rough country 6" lift and its even better . I knew what I was getting myself into "yes you have to cut a cross member " I don't plan on going back . 180k + miles and yes I still have the stock needle bearing for Christ sakes . Honestly just do your research and you will find what your looking for .
    NTXC8D[QUOTED][OP] likes this.
  11. Feb 11, 2023 at 2:15 PM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    Toytech 2.5 BOSS series is adjustable up to 3" over stock. ICON, KINGS, FOX...
    All 3" (up to) coilovers
  12. Feb 11, 2023 at 4:44 PM
    NTXC8D
    Jake
    Dinwiddie, VA
    Thanks for the input guys, appreciate it ! Looking towards 2 inch range now.
    ZColorado likes this.
