Truxedo tonneau question
Discussion in 'Tonneau Covers, Caps and Shells' started by Vraptor, Aug 14, 2010.
  1. Aug 14, 2010 at 7:43 AM
    Vraptor
    Vraptor [OP] Well-Known Member
    Joe
    NoVa
    I am trying to decide between the Truxedo lo pro qt and the Access LE tonneau cover. I am leaning towards the Truxedo but have a question.
    I was wondering if anyone who has a Truxedo knows if the Toyota cargo divider will work with this cover. I know it will not be able to slide the entire length of the bed because of the mount points, but with the over being so low I am not sure if it would fit under. I do not have a cargo divider yet but want to purchase one so I am not exactly sure how high it sits.
    I appreciate any help on this.
  2. Aug 14, 2010 at 10:09 AM
    EricGagne
    EricGagne Well-Known Member
    Eric
    Montreal
    2010 TRD Off Road
    Literider Tonneau Cover, RAM Mount Laptop Support. Uniden CB RTT and awning with self-designed custom rack Dual battery system - National Luna solenoid and monitor, Columbia Overland dual battery tray, 2 Odyssey PC1200 12 circuits Fuse block with 80A macro fuse block "breaker" OME suspension Replaced passenger area with a flat platform for my ARB fridge and camping clothes. Tiregate HG series
    The knobs on the divider go about 1/2" higher than the bed. I don't know if a low profile cover will work but I don't think the very low ones will.
    I hope this helps.
  3. Aug 16, 2010 at 11:58 AM
    TruXedo
    TruXedo New Member
    I'm Kellie from Truxedo. The Lo Pro QT rails protrude in 3" on each side of the truck bed and are at the same level as the top of the bed. It appears that the knobs on the bed divider wlll interfere with our rails. Unfortunately it doesn't look like our cover will work with that bed divider.
    However, it will work with the tie-downs if you don't have the divider.
