Try to get Tonneau cover installed at factory or wait for aftermarket?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LtTaco, Oct 3, 2015.
  1. Oct 26, 2015 at 7:45 PM
    #181
    Larry
    Larry CARL
    CARL
    I saw one at the deslership when I was having my truck serviced. I thought it looked good. Operated well. And would suit my needs. Partly because folded up it appears to be just enough room for my dog kennel.
  2. Oct 27, 2015 at 4:43 AM
    #182
    Nickolai
    Nickolai New Member
    Nick
    ISO '16 MGM DCSB Limited
    I'm also debating on which cover to go with. The BakFlip products seem like my probable choice.
    Does anyone on here have any experience with the Bak Industries Revolver X2? It's a hard roll up cover. But looks more secure (and maybe more waterproof?) than the BakFlip. It also allows you to open/close your tailgate independent of the cover, which would be handy.
    http://youtu.be/oMjYmYSyVb0
    axe and i8boots like this.
  3. Oct 27, 2015 at 4:49 AM
    #183
    baron55
    baron55 Well-Known Member
    2025 Tacoma TRD Sport 4X4
  4. Oct 27, 2015 at 5:21 AM
    #184
    Mr. Torgue
    Mr. Torgue Explosions!!?!!?!?
    2016 7544HHBBP
    LED lighting
    They are, I had a snug top on my first Ranger and it was a 2 man job with at least 8 bolts to pull that thing out in a way that didn't damage the gas shocks. You could pop them off the mounting joint, but that would wear the sockets eventually rendering them useless.
  5. Oct 27, 2015 at 5:37 AM
    #185
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    After dealing with snap covers, hard covers, retractable covers over the years, Nothing beats my high roofline canopy for keeping stuff dry. Can still get 4 tall garbage cans stood upright in there if needed as far as headroom is concerned. Unscrew 4 c-clamps and it comes completely off. 1 person operation to remove it.
    The hard cover was a pain in the ass and heavy as hell. Couldn't put anything taller than the cover/bed edge in the back,,which really sucked.
  6. Oct 27, 2015 at 5:41 AM
    #186
    Racefan15
    Racefan15 Well-Known Member
    Toyota claims it weighs 80 lbs, but had mine off a few times too and it sure doesn't seem that elay.
  7. Oct 27, 2015 at 5:48 AM
    #187
    Racefan15
    Also, on the factory ones like came with my TRD OR, the middle seems to lay flat, but it is the ends (closest to the back window, and the end by the tailgate) that flip up a little giving it the warped look. It really not warped though.
    The cover connects to the truck and locks in place with a latch that kind of looks like a door latch (Ill try to take a few pics to show what I mean). The problem is that the rod the latch snaps down on needs to be located about 1/4" lower on the truck bed so that the cover fits tighter when locked in place. I am brainstorming a way to make that happen, but because neither the latch or the rod are adjustable, I am still thinking of a way to correct.
    Again, it is really not a warping issue, just the front and back need to be adjusted so they lock in place a little tighter.
    Ill have ot post a correction once my little brain has time to sit down and figure out a solution.
  8. Oct 27, 2015 at 12:56 PM
    #188
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    very interested to see what you think. I don't know anything about this brand, did you do a lot of research first. (this is me being lazy and hoping you did some of the work for me already :thumbsup:)
  9. Oct 27, 2015 at 12:57 PM
    #189
    Gingerbeard Man
    Gingerbeard Man Well-Known Member
    Jared
    North Dallas
    2016 MGM DCSB Sport 4x4
    Icon stage 3 tubular 285/70/17 Toyo ATII
    I took photos of my bed after a big rain he had in North Texas, it rained extremely hard for about a day and a half. I had minimal water in my bed afterwards. I will put pics up later.
  10. Oct 27, 2015 at 2:29 PM
    #190
    Aaronp18
    Aaronp18 Well-Known Member
    Vancouver, BC
    2016 White Tacoma TRD Sport 4x4 DCLB
    Hmmm, I'm reconsidering! The Extang Solid Fold 2.0 is available now and it installs and can be taken off really easily if I need the use of the whole bed. Probably 80% of the time the cover will be completely down, maybe more.
    It also sits on top which means you do have a good inch or so more clearance height wise in the bed with the cover on.
    http://www.extang.com/solid-fold-folding-tonneau-covers2.html
    This is much cheaper as well.
    What to do, what to do?
  11. Oct 27, 2015 at 2:49 PM
    #191
    LaPorta
    LaPorta Well-Known Member
    Any/all the ones that roll up, be it BAK or Extang, are not available yet....argh.
    CusterFan likes this.
  12. Oct 27, 2015 at 2:59 PM
    #192
    thefinalstraw
    cheaper than what?? this link is giving me a price of $999 for the 5 foot bed.
  13. Oct 27, 2015 at 3:03 PM
    #193
    Aaronp18
    Vancouver, BC
    Soory
    Sorry, cheaper than the BakFlip F1 which is what my original choice was but it's not available yet!
    From a friend of mine who supplies truck parts I can get the Extang for $850, but the only price in Canada that I can find for the F1 is $1450 for the 2015 model.
  14. Oct 27, 2015 at 3:24 PM
    #194
    thefinalstraw
    thanks for the clarification. i like the looks of the hard top extang, but at the $1000 price point i would rather hold out until the OEM is available at the dealer for the $650 price tag.
  15. Oct 27, 2015 at 3:41 PM
    #195
    Aaronp18
    Vancouver, BC
    I'm in Canada so everything is more expensive, the OEM is $1350 up here. And they need to cut out portions of the bed liner (IIRC) to install it.
    Neither of the Extang or BakFlip require cutting. The BakFlip F1 uses the existing rail system in the bed and the Extang Solid Fold 2.0 sits on top of the bed sides clamping underneath the bed lip with a clamp system.
    The SF2.0 is available now, F1 maybe in December. F1 can fold up to give you access to the whole bed without removing the cover, the SF2.0 looks like it can be removed easily though. The F1 you need to lift in order to close the tailgate then drop down to seal, the SF2.0 sits on top of everything so you can close the tailgate without lifting the cover. The SF2.0 requires 2 latches to lift, the F1 a single pull lifts it - though this could mean the SF2.0 is more secure.
    If I'm going to have the cover down probably 80% of the time I'm starting to think the SF2.0 may be the better option.
  16. Oct 27, 2015 at 3:56 PM
    #196
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    http://tonneaucoversworld.com/undercover-flex.aspx
    I would consider the Undercover Flex if I was going to shell out $900.00 you can get these cheaper by dickering with them, (AutoAnything will give you a discount on them also). My 2nd choice is the Truxedo Lo Pro QT
    http://tonneaucoversworld.com/truxedo-lo-pro-qt.aspx
  17. Oct 27, 2015 at 4:00 PM
    #197
    CusterFan
    http://tonneaucoversworld.com/truxedo-titanium.aspx
    This would be a better designed on the principle of the cover you are asking about. You can get a discount on these as well. AutoAnything will give you a discount also.
  18. Oct 27, 2015 at 5:25 PM
    #198
    Nickolai
    Nickolai New Member
    Nick
    Thanks Scooter. I haven't been a fan of velcro in the past...is this fairly durable?
  19. Oct 27, 2015 at 6:53 PM
    #199
    CusterFan
    http://www.autoanything.com/tonneau-covers/60A1587A0A0.aspx
    Yeah they are. The Velcro is allowed to move a little in the channel so it seals nice and taught. The cross members stay in the cover when you roll it up. Scroll down on the link above and read the reviews. I don't think they have one out yet for the 16' Tacoma though. Another video below.
    https://www.youtube.com/watch?v=_WcT0q_J7Yo
  20. Oct 27, 2015 at 7:40 PM
    #200
    hobolukas
    hobolukas Member
    I just received the 2016 Extang solid fold 2.0 for a 5ft bed. Part number is 83830 and etrailer.com is currently selling it (approx $800). You can find a 5% off promo code if you search on google. I was looking for an easily removable cover that wouldn't need any modifications to the bed and I wasn't concerned that it completely folded up. Haven't tested in wet weather yet so unsure of the waterproofness but overall the seals look pretty good. Only gripe is the bed rails don't go back far enough to keep the end covers attached but other than that it looks great.
