Try to get Tonneau cover installed at factory or wait for aftermarket?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LtTaco, Oct 3, 2015.
  1. Oct 29, 2015 at 10:49 AM
    #241
    VetteVert
    VetteVert Well-Known Member
    '17 Storm Trooper DCSBOR
    Yes. A lot of the installs show drilling those out to fit the larger drain tubes. No thanks.
  2. Oct 29, 2015 at 10:53 AM
    #242
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    I just ordered a Solid Fold 2.0 from Tonneaucovers .com, $789.00 shipped. They stated that it was designed for the 2016 Tacoma . I just hope it fits well.
    Now I just need a truck to put it on. I should be picking up my Tacoma DCLB this Sat.
  3. Oct 29, 2015 at 10:54 AM
    #243
    Bumrush
    Bumrush Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    What I saw was rubber grommets on the cab side of the bed. It's in all the videos I seen.
  4. Oct 29, 2015 at 10:55 AM
    #244
    thefinalstraw
    thefinalstraw Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    that is the cab side - maybe I got gypped out of my grommets.
  5. Oct 29, 2015 at 10:56 AM
    #245
    Bumrush
    Brian
    Middle TN
    Well I wasn't sure if they have it, I am still waiting on mine. But I guess that answers it.
  6. Oct 29, 2015 at 10:58 AM
    #246
    Bumrush
    Brian
    Middle TN
    upload_2015-10-29_12-57-55.jpgI thought it would be like this.
  7. Oct 29, 2015 at 11:00 AM
    #247
    VetteVert
    Doesn't look like a Taco
  8. Oct 29, 2015 at 11:02 AM
    #248
    Ducman
    Ducman Active Member
    NJ
    2016 MGM Tacoma Limited 4X4
    Just reviewed Bakflip installation video says that the hole needs to be opened up with a 7/8ths drill bit, that's not to bad, as the holes were already there and just one of them need to be enlarged.
  9. Oct 29, 2015 at 11:04 AM
    #249
    Aaronp18
    Aaronp18 Well-Known Member
    Vancouver, BC
    2016 White Tacoma TRD Sport 4x4 DCLB
    I know the Solid Fold 2.0 is easy to remove, which is an asset for myself. There's times when i have 4 (2 adult 2 kids) kayaks in the back and I'll need to use the whole bed. I would either need a cover that folds completely to the cab (but then it blocks the back window) or is easily removed.
    Which is why the SF2.0 looks like the best option for what I want to use it for.
  10. Oct 29, 2015 at 11:05 AM
    #250
    Ducman
    NJ
    https://www.youtube.com/watch?v=HLXIeKImt4Y
  11. Oct 29, 2015 at 11:28 AM
    #251
    Bumrush
    Brian
    Middle TN
  12. Oct 29, 2015 at 11:32 AM
    #252
    81435
    81435 Well-Known Member
    Colorado
    2016 TRD OR AC MGM
    3/2 lift, TRD Pro wheels, 275/70/17 KO2's
    Anyone know how effective the drain tubes in the front (on the bakflip) would be if you have a lift/level on your truck? I would assume the drain tubes are really designed to work with a truck with the factory rake.
  13. Oct 29, 2015 at 12:02 PM
    #253
    Kbattlefield
    Kbattlefield Well-Known Member
    Kevin
    2015 metallic grey double cab TRD off-road
    What website is selling the Fold-a-cover G4 elite for the cheapest price? I am looking for comparison to the backflip g2 price (799.88). I do not see it on tonneaucovers.com. Do you not need to drill drain tubes with the G4 elite?
  14. Oct 29, 2015 at 12:05 PM
    #254
    Aaronp18
    Vancouver, BC
    I don't believe you do because it sits on top of the bed rails. So the water doesn't enter the bed area so that it needs a drainage system.
  15. Oct 29, 2015 at 12:20 PM
    #255
    erikjon
    erikjon Member
    Saint Paul, MN
    2016 DCSB TRD OR 4x4
    I think you're right. But man, not a straightforward install! Have you looked at the instructions for that one? Certainly not a quick removal, should you need to use your entire bed in the future. http://www.steffensautomotive.com/installguides/3641XX-WEB-G4-Elite.pdf
    As an aside, I wonder if rather than drilling out the drain holes, one could just use a barbed fitting, hot glue it into the existing bed drainage holes, then connect up the drain hose? I'm sure the flow rate would be sufficient, no? Plus, the drainage channel and tubing is really a secondary precaution for those really hard rains when water penetrates the top seal.
  16. Oct 29, 2015 at 12:30 PM
    #256
    Aaronp18
    Vancouver, BC
    Yup, that's why after weighing all the options and knowing what I want out of a hard cover the Extang Solid Fold 2.0 is the one for me!
  17. Oct 29, 2015 at 12:32 PM
    #257
    erikjon
    erikjon Member
    Saint Paul, MN
    Agreed! That will likely be the one I order as well. Keep us posted when/if you get it installed!
  18. Oct 29, 2015 at 12:33 PM
    #258
    Aaronp18
    Vancouver, BC
    Will do, it's ordered - ETA is a couple weeks out. Things were delayed here in Canada as they only released the 2016s for sale Oct. 16th.
    Definitely will post pics and pros/cons once I get it on.
  19. Oct 29, 2015 at 12:38 PM
    #259
    Ares32
    Ares32 Well-Known Member
    America
    2016 MGM TRD off road DCSB M/T
    And that is why you can wait for another option. You don't want that piece of shit on your truck and that's up to you. At the moment I want something that is durable, keeps shit secure, and folds at least half the bed. If I have problems with the janky ass latches I'll just rig something that works. My .02
  20. Oct 29, 2015 at 1:05 PM
    #260
    Bumrush
    Brian
    Middle TN
    Have at it, just my opinion.
    Ares32[QUOTED] likes this.
